VX2255wm won't turn on
    I have a problems with my Viewsonic VX2255wm monitor.
    Few days ago the monitor started to have a problem, the monitor was working fine but each time my computer was stopped/started the led of the monitor was blue and the screen was black, and when I tried to push the power button of the screen it seems to be frozen, Blue led and black screen. So I decided to remove the power cable and to plug it again and it worked.
    And I did it everyday.
    But today the monitor (with blue led and blackscreen) when I unplug/plug the power the blue light goes on during 2seconds, off during 1seconds and then ON again (Blue led light, black screen, power button frozen)
    And even when I shut the computer down my led is still blue.
    I tried to push power button during 30seconds, another power cable, another PC.
    So I'm here first to see if someone has already seen this sort of problems before doing anything. (NOTE : The whole screen is off, not just backlight, I can see it with my flash light)
    Do you think this problem can be a capacitor problem ? Power supply ? (So why plug/unplug the screen did the trick last days ?)
    Note (if it can help to see where the problem come from) : There was a power outage in my street on week ago that has ruin my Printer.
    Thanks !
    I will post pictures later when I will be able to disassemble the screen
    Re: VX2255wm won't turn on
    Hello
    I'm here to post some pictures
    http://img1.imagilive.com/0215/IMG_20150219_212333.jpg
    http://img1.imagilive.com/0215/IMG_20150219_212342.jpg
    http://img1.imagilive.com/0215/IMG_20150219_212401.jpg
    I see one Bad Cap.
    I will try replace this one
    The VX2255wm is not easy to disassemble
      I'm alone here ^^
      I replaced the Capacitor (1000uf 10V)
      SCreen fixed
        You should of changed all capacitors
          Leaving default caps can damage my screen ? or it is just to avoid having issues in the future with the others ?
          I have ordered all capacitors but I changed only one because I'm not a very good welder i don't want to damage a working screen
            You can wait for monitor to fail again, mean while you can practice soldering
            YouTube is a great place to learn.
