CCFL-LED conversion wiring question
+ More Options
Posts
  • Sledge Fingerhammers
    • Feb 2015
    • 8
    Greetings from Texas. LTLFTP and all that, because all my lurkage has come up dry on this one.
    I have a Westinghouse L1951NW with a Delta 19M009 PSU that won't fire the CCFLs, and I decided to just go ahead and see what one of those LED conversion kits would do. Problem is, between the Chinglish the instructions are written in and the different PBC legends used by different MFRs, I'm stumped on wiring the thing in.
    The LED driver board has VIN-ENA-DIM-GND. VIN, DIM and GND are obvious. ENA I tracked down as ENAble, or ON/OFF. OKfine. My PSU, however, speaks another language.
    The connector between PSU and mainboard is 16 pins, with #1 marked, but not #2 or #15, so I'll guess at the sequence:
    Row 1 :1-8
    Row 2: 9-16. So:
    1 AOL+
    2 AOR+
    3"SHUT"
    4 V_adj
    5 +5V
    6 DET
    7 GND
    8 EVA
    9 AOL-
    10 AOR-
    11 MUTE
    12 +13.8V
    13 +5V
    14 GND
    15 GND
    16 ADJ
    Upper and lower case as found. The 19m005 board that was originally in this thing had "VADJ" at pin 16, all others the same.
    13.8v and GND are easy. Where I stop is, which "adj" to connect to DIM, and is "SHUT" their word for ENA or ON-OFF? Or have they merely misspelled ENA as EVA?
    Anyone translate Delta-to English?
