DAC-12M030 rescue
  • Volt
    • Dec 2014
    • FRANCE
    DAC-12M030 rescue
    Hello everybody,
    First, i'm french so i'm very sorry for my bad english. Don't hesitate to correct me
    So, i need your help to rescue my computer display. I think there is a problem on the power supply board : DAC12M030. (A190E2).
    There is a little sound when the display is switched off. But when i switch on the ON/OFF button. The sound become louder and louder during five seconds, the display shows some white lines (CCFL lamps lights i think) during 0,5 seconds and the display become black.
    When i did the same test with a PC connected to the display, i could see my desktop during these 0,5 seconds.
    I have read some threads on this problem on your board like that :
    https://www.badcaps.net/forum/showth...t=29620&page=3
    I have tested the four AOP605 and i think it is OK, i never measure less than 6MOhms.
    When i disconnect the fuse F200. There is nothing when i switch on.
    My board seems like visually OK.
    I will post some photos.
    Thank's you for your help
    Volt
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • twonk9098
    Lenovo Legion 5 high fan spin turns off after 34 seconds
    by twonk9098
    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
    I have tried a few new bios but exactly...
    07-14-2024, 11:19 AM
  • liquidzorch
    Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
    by liquidzorch
    Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
    10-18-2024, 05:19 PM
  • Rick_1234
    by Rick_1234
    Good evening, gentlemen.
    Things I tried
    06-22-2024, 04:44 PM
  • PowellSkier
    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
    by PowellSkier
    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
    06-17-2024, 11:43 AM
