LG Flatron M1721a - NO SCREEN
  • olorin
    • Sep 2013
    • 82
    • Greece
    Hi!
    This screen, while it has sound (is TV and PC monitor), has no have image.Displays momentarily for 1 second and then just black as TV also as monitor for pc.I opened it and the power supply had 5 very bloated capacitors.Replaced them but the problem was not solved ..... What can blame?
  • kasfamily
    • Aug 2014
    • 772
    • Russia
    Re: LG Flatron M1721a - NO SCREEN
    check CCFL (Lamps)
    • olorin
      • Sep 2013
      • 82
      • Greece
      Originally posted by kasfamily
      check CCFL (Lamps)
      There is not CCFl lamps because I checked with flashlight the screen and there seems no trace of the screen.
      • kasfamily
        • Aug 2014
        • 772
        • Russia
        Show photos of the inverter
        • turmix
          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
          by turmix
          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
          During another reassembly, I made a mistake, and...
          01-29-2024, 03:48 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
          by momaka
          03-15-2023, 10:17 PM
        • abajor
          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
          by abajor
          Having this very weird issue.
          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
          I swapped with a working screen from an A2141 waiting for parts.
          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
          04-27-2024, 01:37 PM
        • 3D Modelka
          AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
          by 3D Modelka
          Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
          02-09-2024, 02:42 AM
