Samsung S19B300B Firmware Need
  • babakmaku
    • Jun 2019
    • 40
    • Iran
    hi.This file is damage please give new file or repair this file.
    Samsung S19B300B
    Model Code: LS19B300BS/ZN
    PCB Code: BN41-01787B rev: MP1.0
    Model: NT68652_1A1D
    CPU: MagicColor SE1159LMHL-NT
    Panel Model: HT185WX1-300
  • lotas
    • Jan 2016
    • 4554
    • Russia
    Try it, maybe something will work.
    • babakmaku
      • Jun 2019
      • 40
      • Iran
      Thanks.backlight is on but no display
      • GeckoGreen
        Samsung service bulletin: need firmware file for PN63C550 TV
        by GeckoGreen
        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
        Will you please help me get the [2D63]LOGIC.bin file for my TV?
        05-17-2025, 02:47 PM
        09-07-2024, 05:50 AM
      • Daniel Larsson
        Firmware file for Marantz NR1501 needed
        by Daniel Larsson
        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
        The content of these seems to be useless as far...
        05-23-2025, 04:11 AM
        09-06-2024, 11:40 PM
