ASUS MW221 image problem
  • Behemot
    • 4845
    • CZ
    Got this one for <20 bucks. Preventive recap with adding mising caps on PSU did not help. There are NCC KY caps on signal board, measured OK. Does not seem to bad bad joint between TCon adn panel, I tried pressing it when it was showing this with no change.
    No idea really. Is it TCon? Signal board?
  • bammbammfran
    • Apr 2014
    • 476
    Re: ASUS MW221 image problem
    odd picture
    Just an idea: did you see if there is a reset to factory default in the on screen menu (If that is available )
    • jetadm123
      • 2169
      Have you tried cleaning/reseating the ribbon cable from the signal board to t-con board. Also possible that there are some dried out caps on the signal board.
      • Behemot
        • 4845
        • CZ
        Originally posted by bammbammfran
        odd picture
        Can try but something tells me this one is pretty long shot
        Sure on both ends. Needed to remove the signal board. As I stated, all caps there are KY, checked OK.
        • bammbammfran
          • Apr 2014
          • 476
          do those lines in the screen move ?
          I ask because I think that has a chi mei m220z screen which I have found to have a lot of issues (both with picture and with bulbs) and the ribbon connection on those SUCKS
          • Behemot
            • 4845
            • CZ
            It seems pretty much static…
            • bammbammfran
              • Apr 2014
              • 476
              well, If those side lines show up a a boot up or bios screen than it is probably the panel
              • Behemot
                • 4845
                • CZ
                It is actually OK for some time and than it starts. Not immediatelly when you turn the display on.
                If you mean the blue it is 1280x1024 image on wide screen…
                • jetadm123
                  • 2169
                  Oops! Missed the part in post #1 where you replaced the signal board caps. Since the problem doesn't start immediately, try accelerating the problem by heating the boards with a hair dryer. I would try heating the signal board first, then the t-con board.
                  • Behemot
                    • 4845
                    • CZ
                    You are missing more of it, I did not replace them.
                    I will swap the whole display, that will tell me more where to look while being able to do something else in the meantime…
                    • bammbammfran
                      • Apr 2014
                      • 476
                      I first thought that is may have been a resized screen but I could still see what looked like part of the picture behind the blue, so I changed my thoughts.
                      Time for the heatgun or air cans OR as you said, swap the panel.
                      • Behemot
                        • 4845
                        • CZ
                        Seems to be signal board, it started almost immediatelly when I swaped panel and resolution to 1680x1050 (I think I left 1440x900 yesterday so it probably took more time because of it).
                        Reseting to defautls did nothing. The problems occurs after aprox. 10 seconds each time I turn it off and on again. I can also see what looks like „history“, e.g. when I open menu and than close it, I can see some remaints of the window in different position. Is it possible that one DRAM chip (EM636165TS-5) went bad? Or something else?
                        • vabea
                          Asus X550LD Image problem
                          by vabea
                          Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                          Thanks...
                          04-07-2025, 08:33 AM
                        • lazaro.089
                          Asus Zephyrus M16 / GU603ZW problem
                          by lazaro.089
                          Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                          CPU: Core i9-12900H
                          Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                          Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                          The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                          08-26-2025, 06:33 PM
                        • AtelierRepa
                          ASUS X712JA problem
                          by AtelierRepa
                          I have a problem with the bios, let me explain.
                          With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                          I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                          My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                          The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                          06-15-2024, 04:33 AM
                        • Dobrowol
                          Asus GA402RK keyboard and kb backlight problem
                          by Dobrowol
                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                          04-28-2025, 04:30 PM
                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-07-2024, 02:50 AM
