HP Pavilion vf15 (15" Flat Panel LCD Monitor)
  • jdmillard
    • Mar 2014
    • 39
    Re: HP Pavilion vf15 (15" Flat Panel LCD Monitor)
    Nope. I got it from my parents a long time ago and I seriously doubt that they would ever have it worked on... ever. They would just buy a new one.
    • jdmillard
      • Mar 2014
      • 39
      Here is a better view of the burn. I was having trouble getting a crisp image of the back without getting glare from the flash. I even went to a different room with better lighting and tried without the flash. So i just uploaded a bunch of them. The corner that is shown is the "top-right" corner. So I flipped the board as though it were a page from a book. The burn mark would be right below where you see the IN, OUT, ADJ
      EDIT: In the first image, is that thing to the left of the voltage regulator supposed to be a Philips screw (that got melted)? It looks crazy now.
      • jdmillard
        • Mar 2014
        • 39
        Here is a question:
        What is that black thing? (more detail in the image)
        EDIT: the resistance across it is zero. I don't know if that is significant, but there you go.
        EDIT: there are 2 similar-looking ones on the other side of the board. I don't know if they do the same thing, but they both had solid resistance across them.
        The number printed on it is impossible to see in the image, but it's
        75B
        46 (the six may be an 8 or a B... difficult to tell. doubt it's a B though because it doesn't look like the B in the number above it)
        EDIT: Now that i look closer, it seems that there's some black stuff underneath it (between the two solder points) as though it had melted there. It seems like little black blobs, like puddles. But they are very small and there are none of those anywhere else on the board.
          I was going to ask you to check that ZENER DIODE (ZD904, ZD = ZENER DIODE) if it is shown as shorted circuit. It is the one that got real hot and caused the board to turn brown.
          I cannot read the print on the body. I think we found the cause of the problem.
          • jdmillard
            • Mar 2014
            • 39
            So what caused it to burn? Was it the endless "mileage" on worn out caps? Or was it simply just too old to carry on and would have had a super nova regardless of the other parts?
              It can be from over voltage is being applied and it tried to clamp down the voltage from exceeding the Zener voltage, or it just failed. I will have to trace out the circuit to see how it is connected.
                What is this component? Jumper wire or a resistor? I cannot see it on the top side of the board.
                • jdmillard
                  • Mar 2014
                  • 39
                  I have no issue with swapping out the burnt diode. And since I'll already be paying shipping (the majority of the cost), I can swap out the startup cap and those 2 transistors I already pulled out just for good measure.
                  I'm wondering if there will still be overvoltage or some other problem that will just burn it out again. Would it be possible to get another diode with better specs? or will that just cause problems?
                  • jdmillard
                    • Mar 2014
                    • 39
                    It's just a bridge (I guess you say the technical term is a jumper wire). The two spots below it are full components, but the one you circled is just a jumper. It jumps directly to the right ("due East")
                      OK, I traced out the ZD904 connection, it is being used to clamp down the spike on the output voltage feeding the inverter output section incase the regulator went out off control. You can remove it for now and apply the power to the board and measure the DC voltage on the two pads of this ZENER Diode so I can determine the Zener voltage, just power it just long enough to see the steady voltage.
                      • jdmillard
                        • Mar 2014
                        • 39
                        Sorry to flood you with pictures, I'm trying to get you some better lighting. I adjusted some things and snapped a bunch more. There's some glare, but it's on another part of the board.
                        EDIT: Nevermind
                          I believe that is the 7.5V Zener but not 100%. I will have to look at some of my spare board bins to see if I have one of this board.
                          • jdmillard
                            • Mar 2014
                            • 39
                            Well well. I just tested and got 7.66V. I come back to refresh page and you're two steps ahead of me. So does the 75B have anything to do with the 7.5? or was that just a coincidence?
                            EDIT: Also, it fell apart when I took it off the board. I didn't even pull very hard. That thing really was dead. And the click only happened one time (I'm guessing you expected that that).
                              Here is the similar function of ZD904 used in another HP monitor.
                              https://cdn.badcaps-static.com/pdfs/...9977010163.pdf
                              Most power supply design does not use this type of setup for protection.
                              So if you put the transistors back in the monitor should work.
                              It is probably TPSMP7.5, OR 7.5A.
                              • jdmillard
                                • Mar 2014
                                • 39
                                So what is the worst-case-scenario if I just leave it (the Zener diode) out?
                                  You can leave it off for testing to see if you have other problems with the monitor.
                                  • jdmillard
                                    • Mar 2014
                                    • 39
                                    So I test to rule out any other component failures. If everything looks good, then I'm clear to order and replace the necessary diode and put everything back together. Right?
                                      Yes.
                                      • jdmillard
                                        • Mar 2014
                                        • 39
                                        I'm getting a constant 5V. But that is without a load. I'm gonna plug the rest in and see how it goes.
                                        • jdmillard
                                          • Mar 2014
                                          • 39
                                          Success! I plugged it all in, fired it all up, added it as an extended screen to my laptop and it performed flawlessly.
                                          Bud - If you didn't live 11 hours away, I'd buy you lunch my friend. You are an excellent troubleshooter and you explain things well. This has been a great experience for me. The monitor is outdated, but the things I learned certainly are not!
                                            HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-12-2024, 03:44 PM
                                            HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
