Samsung SyncMaster 226 slow to start?
  • EsqzMe
    • Sep 2013
    • 56
    My trusty monitor recently developed a nasty habit of the display flashing rapidly when first powered up, and keeps flashing for several minutes before stabilizing.
    The display (computer boot screen) is there, just rapidly blinking on-off. No sounds or noises.
    It will give you a headache watching it.
    I am using a Dell Latitude in a docking station.
    When I just work on the lap top there is no problem, so I know it is the monitor.
    This began a couple of months ago, and seems to be getting worse. I just turn it on and leave the room for a while before returning to finish the boot process.
    One more tid-bit....for a few years now the display will randomly "flash" once, like disappear and come back immediately. Doesn't happen very often,maybe a few times a day (I may be on the computer 8+ hours at a time).
    I am sure that is related and had taken it as a sign of impending doom when it began, but the monitor has continued to work for quite some time, and the display (when stable) is crystal clear and normal.
    For the last couple of weeks I have just left the system running 24 hours a day so I won't have to wait to start every morning. Still chugging along. But I would rather power down at night.
    Haven't opened it up yet....now that I have found this most excellent forum I thought I would see if any of you have recommendations of what to look for or at when I do?
    Wonder what this thingy on the circuit board does??
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Samsung SyncMaster 226 slow to start?
    Almost certainly bad caps on the secondary of the power board. Saw this in the exact same monitor, the caps that went bad were CapXon. Yours probably uses them as well, so open it up and post some pictures.
    • EsqzMe
      • Sep 2013
      • 56
      Thanks,
      I'll crack her open tomorrow after work, and show you what I find.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Okay. If it's bad caps, it's an easy fix!
        • EsqzMe
          • Sep 2013
          • 56
          Took it apart and....there they are!!
          2 swollen caps!! Crappy picture. Will try again later. Off to dinner now.....
          • EsqzMe
            • Sep 2013
            • 56
            2 caps with swollen tops, 820 uf 25 v, located in the bottom right corner of that previous photo........everything else looks good. They haven't blown yet, but are on the way. Hence the symptoms that clear up after things warm up.?
            Off to Ack Radio for replacements. Thanks to the originators of this forum for giving me enough info to overcome my insecurities and dive back into circuit boards after 40 years.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              "Off to Ack Radio for replacements." NOO!
              RadioShack sells crappy capacitors too. Buy some good ones from here.
              You should also replace the rest of the lower voltage capacitors. There are 3 others on that board that should be replaced
              Muh-soggy-knee
              • EsqzMe
                • Sep 2013
                • 56
                Ack Radio in Atlanta Ga (with a location in Birmingham AL) is THE supplier of circuit board components in the North Georgia area. They aren't a Radio Shack....all the TV or electronic repair shops and amateur radio operators around here have been using them for decades.
                I'll take my chances locally.
                Thanks for the suggestion to replace them all. This monitor has been in constant service for about 7 years now, and just started acting up. I've been quite pleased with the performance.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  AHHH I see now xD
                  I thought you meant radio shack
                  Muh-soggy-knee
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Just make sure to get low ESR caps, with dimensions that will fit
                    • EsqzMe
                      • Sep 2013
                      • 56
                      Originally posted by ben7
                      AHHH I see now xD
                      The Radio Shack stores in my area are worthless.....
                      • EsqzMe
                        • Sep 2013
                        • 56
                        Happy to report that my monitor is now functioning like new again !!!
                        Less than $5 for a few new caps and an hour of my time and.....
                        And, yes...they were CapXon brand....not anymore.
                        Thanks to this community and the information I gleaned on the forum
                        ...Now to tackle my 50 inch Samsung Plasma TV that doesn't turn on anymore!!!
                        Look for a post in THAT thread next..
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Good job! Glad to hear you got it working What caps did you use as replacements?
                          • EsqzMe
                            • Sep 2013
                            • 56
                            Nichicon caps.....my supply store was out of 840 uf 25v, so I used 1000 uf 25v (within 20%)...she's starts right up now, screen clear as can be. !!
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              Adding more capacitance for filtering is just fine. Good work!
                                09-07-2024, 05:50 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 06:20 PM
