SyncMaster 225BW Intermittent blackout
  • arjfca
    • May 2013
    Hello
    My SyncMaster 225BW as an intermittent problem
    After few hour, the screen go black for few second then image return.
    Other time, image won't return, I need to use the power switch for an off-on cycle, then image return. When this occur, the blue power led will stay on, but pressing on the power button has no effect at all. Screen is frozen.
    Also last night I had strange color in the lower half of the screen. Color was changed, but the definition was fine.
    I had changed some capacitors, but problem remain.
    Any idea?
    Martin
    Re: SyncMaster 225BW Intermittent blackout
    When the screen blacks out, can you see it glowing in a dark room, or does it go completely out?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      iirc the 225bw i had with intermittants had bad sm lytics on the logic board.
      it would lock up like you describe.these is a 32 page thread on this unit and i posted the fix there.
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • protocold
        MacBook Pro 15" 2010 820-2850 intermittent charging
        by protocold
        I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
        I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
        when it is not intermittent:
        PPVBAT_G3H_CHGR_R is 12.07v
        when it is intermittent:
        When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
        when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
        data line on the battery...
        07-25-2025, 08:18 PM
      • ambet22
        dell 3310 blackout with intermittent power
        by ambet22
        please help me..clean my bin file...
        07-25-2021, 12:30 AM
      • soopacrucial
        by soopacrucial
        Hi folks,
        10-29-2024, 02:40 PM
      • neilc6
        Sold Sharp LC-50LB370U Board on Ebay - Return Requested
        by neilc6
        Sold this board on ebay with this warning in the description and pic of working TV.
        "Pulled from a TV with a damaged panel. NO REFUNDS.
        This model suffers from LED backlight failures. Make sure your backlights are working before replacing boards. Symptom is TV turns on and off with no backlight or a flash of backlights."
        Ebay Return Request
        Reason for return - Doesn't work or defective
        Details - Powersupply board has sound,but verry dark screen.I would like to return,You send for me another one. Thank You.
        With ebay, if...
        07-16-2021, 04:00 PM
