Sony multiscan 500PS
  • starfury1
    • May 2006
    • 1256
    HI All
    Well I got a Sony 21" 500PS..... nice monitor but has now shown a slight problem
    The thing is *breathing, with maybe slight barrel distortion
    (*for want of a better technical term )
    although it is staying in focus.
    Also happens at startup
    (so ruling out a long thermal issue here)
    lastly seems to be happing more so at the bottom then the top (if at all at the top)
    Now after doing a bit of searching and reading some of the service manual
    This is going to be a fun to pull down and room is a little limited to keep this monster in pieces.
    So I am just wondering if anyone who has worked on these babies has advice on whats best to replace or check while I am in there as I am aiming to pull it down replace/check caps solder joints etc.
    If I can I would like to replace likely suspects then have them fail a bit further on
    At this point its a symptom me thinks and would like to nip it in the bud before it becomes a real fault condition.
    Thank you all for any help or advice
    Cheers
    Err if any one needs the pdf pm me
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
  • ifrythings
    • Apr 2006
    • 19
    Re: Sony multiscan 500PS
    A little late, but to me it sounds like your ABL (Automatic Britness Limiter) line is not able to change completely when it close to the end of the scan time.
    It could be a bad opamp or able drive transistor.
    Other than that, I'm a bit stump as you are, only other thing I can think of is pour B+ regulation.
    • starfury1
      • May 2006
      • 1256
      Thanks for the Reply Ifrythings
      Yeah did pull it down to have a squizz no obvious signs of cap failure
      (not to say they aren't)
      There is from what a gather an ic that is known to cause problems with these in the vertical somewhere.
      (have to find the info again)
      My suspicion was Voltage supply regulation due to caps ...ok well more my hope really... bad caps
      As you say could be semiconductor problem (hoping not really) from what I can find they do have some issues in this regard.
      or other possibility is dry joint from heat, they do run very warm
      Anyway as I said, rather then let it possibly escalate into a more major problem I'm not using it
      Was really looking at doing more a shotgun repair/replacement rather then doing the right thing and working out via circuit analysis where the exact problem lies.
      Don't really have the space to keep this beast in pieces or a decent work bench setup.
      power supply PCB
      There are few suspect joints on IC690, 630 which is
      standby 8+ dgus, power and heater SW
      anyway a few photos for future reference
      • starfury1
        • May 2006
        • 1256
        OK seem my worse fears may be realized, its possibly not a PSU issue
        There is an ic CXA2043Q that is a know issue semiconductor and the symptoms on this web page
        match (just "find in" page search 500ps, its near the bottom)
        The thing that had me scratching my head a bit about it was the very fact that it was doing it on the lower half and not the top when I was thinking about supply reg problem.
        Anyway if I am lucky it might be a surrounding component but knowing my luck it will be the chip.
        yet to check location of it in service manual
        From what I understand "sometimes DAS alignment is needed, after replacing IC007" (Sony p/n 8-752-078-46)
        anyway see what happens
        • starfury1
          • May 2006
          • 1256
          Just so you know if you didn't...that chips NOT Cheap!
          About US$ 75 from one site. (try about $100 possibly plus AU) for CXA2043Q
          Yet to really source and check in Oz thought.
          I have seen monitors this size going on ebay AU for less then $200 AU "used"
          (working or claimed to be)
          So just beware if you are looking for a cheap fix on second hand unit off auction sites that has fault listed as vertical or geometry problems that this chip is a good possibility for being the fault.
          As to the repair of mine.... well at that price for the chip......I am debating if its really worth while ...still haven't checked other possibilities....stopped when I found that and put it aside for the moment.
          Money could be better spent on a TFT screen me thinks
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
          • patricksurry
            Sony Bravia XBR 55X900E cycling through test patterns: which board(s) to replace?
            by patricksurry
            We had a power outage but TV seemed to be working fine afterward. This morning it showed a "grainy" picture, and then next time we turned it on it's stuck in a test-pattern loop. None of the resets I've tried have any effect, including unplug/wait/plug in - it immediately goes into this cycling test pattern.
            Does this suggest the main board needs replaced? The TV is about 5 years old, picture still looks great (tho limiting to crisp red/green/blue/white lacks some variety ...
            04-08-2023, 06:45 AM
            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
            09-06-2024, 05:30 AM
