LCD Disection (Caps List by Model)
  • PedroDaGr8
    • Oct 2006
    • 130
    I thought that maybe listing some of the information about what is inside of certain displays will help people recognize what is inside and what couple be problematic. I am including the the three main parts where cap failure can occur (PSU, Backlight Inverter and Video Input Board). Maybe if there is enough interest then a mod or someone can turn this into a sticky where everyone lists the details of their monitors, revisions etc. I opened it to make sure all of the caps were ok before I sold it, I didn't want a cap that has already gone bad but wasn't causing problems to be a problem later. Since it was still working I am not going to replace any of the caps, just don't want to break it, plus I need the money for knee surgery.
    So here we go, for my first one.
    Mfr: Viewsonic
    M/N: VP171b
    PSU:
    Li-Shin AREX 94V-0
    2 Panasonic 16V 1000uF 105oC HFA
    1 Panasonic (unknown value because epoxy covered that side, but it is about 1inhc in round, and what I can see says Ce GH)
    1 Rubycon XYG 50V 22uF
    Backlight Inverter:
    Emax 44.61101.001
    2 HERMEI 25V 100uF
    1 SSA 50V 2.2uF (M)P1 CE 105oC
    4 3kV 22J Ceramic caps
    2 250V PMS124J Ceramic Caps
    Video Board:
    Coretronic Corp
    Genesis gm5120 chip
    13 Taicon 16V 180uF 0304(M) 105oC (VT)
    2 Taicon 10V 1000uF 0304(M) 105oC (HF)
    2 Taicon 25V 10uF 0302(M) 105oC (PW)
    1 Taicon 16V 2200uF 0238(M) 105oC (PW)
    1 Taicon 16V 470uF 0246(M) 105oC (VZ)
    Mods: If this does end up becoming a useful list, feel free to edit my above post to remove parts and/or change the title as you see fit.
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
