Samsung 740n black after a sec
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    I dug out a 740n LCD with IP-35135B PSU, which I had stored away. I knew I had taken out the lamps but turns out that PSU is faulty too. I just tested it with CCFL-s which are in 100% working condition. They turn off after a second.
    I tested transformers´ (TM-1222) secondaries, which were 1300 and 1306 ohms.
    All caps are replaced.
    I even noticed I had replaced previous mosfets with a couple of new ones.
    Without any load, 5V rail reads 5.2V and 13V rail reads 18.3V.
    I even randomly checked diodes for shortages - all OK
    Is there anything else I should check?
    09-07-2024, 05:50 AM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
    09-06-2024, 11:40 PM
