i have a IBM 6636-hb1 lcd monitor.Its power light up but no display on screen
IBM 6636-hb1
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
Have had two Acer K272HUL monitors die with the same symptoms:
- Blue power light is illuminated while the monitor is plugged in
- Black screen (no splash screen, etc.)
- Power button doesn't do anything
Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
Power supply voltages are fine.
There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
Anyone have any ideas?...-
12-09-2023, 10:22 PM -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... - Loading...
