Acer AL1917 restarting
+ More Options
Posts
  • Behemot
    • 4845
    • CZ
    When I first got it, it didn't work at all - blown rectifier and fuse on primary side. After replacing them I just fired it on for a couple seconds, seemed good.
    Than I recapped it just for sure (full of Taicon and CapXon), now, when everything is connected, the display powers of for a fraction of seconds, than off and on again over and over. Unpluging CCFL stops this behaviour, I see image using flashlight. Changing all the caps on inverter power supply (various 25V caps, there is up to 24 V on it) back did not help.
    This leads me to bad lamp, do you think it's possible? If it was shorted transformer or transistors on inverter side, I think it would not power on at all even without CCFLs connected.
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Acer AL1917 restarting
    do you have spare ccfls, just for a try? You know that if the ccfls are aging they drain much power, maybe this puts the system in a restart loop.
    • Behemot
      • 4845
      • CZ
      I can open one display I repaired recently. Maybe will take photos than too :-D For a quick try (connecting it from the second display directly into this firsts inverter) that should not be a problem…
      • retiredcaps
        • Apr 2010
        • 9271
        Just curious, what voltages do you get across the
        1) big filter cap? Is it stable?
        2) little startup cap? Is it stable?
        3) 5V SB?
        when the problem happens?
        --- begin sig file ---
        --- end sig file ---
        • Behemot
          • 4845
          • CZ
          Immediatelly as I plug in power cord.
          Didn't measure voltage on input cap, but on the outputs everything was smooth (having just the power board alone, data board and CCFL unplugged).
          • senndogg
            • Dec 2011
            • 383
            • Albania
            yes, you can use them from a second monitor.
            if you think you will be repairing more and more monitors, you have to collect several ccfls (of different sizes). they will be handy!
            • Behemot
              • 4845
              • CZ
              Well U usually resell whole display if electronics is bad, never encountered bad CCFLs so far.
                "Changing all the caps on inverter power supply (various 25V caps, there is up to 24 V on it)" If it really has 24VDC on them, that is way too high for 19" monitor, typical 19" will use 14~18VDC for running the inverter circuits.
                You can also use this for testing inverter circuits.
                http://s807.photobucket.com/albums/y...g%20old%20CFL/
                • Behemot
                  • 4845
                  • CZ
                  24 V without load, than it drops down to 22 V or so.
                  It has 5 V, 13,8 V for data/audio board, another separate 16-17 V rail and this 22 V for inverter. Most likely for better efficiency. Delta board.
                    Does your board look like this?
                    http://lcdalternatives.com/Repair-Ki...-P2060847.aspx
                    It sure does not sound like what you have, the AL1917.
                    Can we see the pictures?
                    • Behemot
                      • 4845
                      • CZ
                      Not even close…gimme some time, I have to finish some reviews and computer builds, than I will return to this again
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Check to see if there are any pinched HV wires. Also check for bad solder joints!
                        Muh-soggy-knee
                        • Behemot
                          • 4845
                          • CZ
                          Yeeah I checked for cold joints right away, didn't see anything bad. Seems that Delta made good work in soldering.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Check the MOSFETs that drive the transformers.
                            Is it happening with only one ccfl? or both?
                            Try changing the startup capacitor too
                            Muh-soggy-knee
                            • Behemot
                              • 4845
                              • CZ
                              Even though there are two transformers in invertor, there is only one tube. At least I believe so. THe thing is, there are another four tiny transformers with CCFL-like connector, and I don't have any idea where it is attached to…
                              Didn't check transistors but I think if they were bad (short), it would restart/go to protect mode immediatelly, no? They are before the transformers thus still under voltage from the power supply part.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                One could be open circuit.
                                There must be more than one ccfl in this thing.
                                Could be get some pictures?
                                Muh-soggy-knee
                                  Are you sure this is AL1917? Those 4 tiny transformers are the high voltage balancers for lamps.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Yep, AL1917 C (line below it says: Version: 1917 Cs). Can they change whole interior with new revision??
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Yes, that is why we always ask for pictures.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        I told ya I cannot do it right now, wait a while, OK? If it is supposed to be any good, I need room, time and equipment for that. I do not have any right now, there are computer parts everywhere and I need to finish this first.
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF114-34-P3RG + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P3RG + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P3RG + Pack Gold Acer 14'' boardview and SF114-34-P3RG + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
