Re: Acer AL1917 restarting
thank you so much back to square one again.
I am not 100% sure, but I think the southern trace is going under the lower diode and should be connected with the right joint of the SMD position which is vacant there.Leave a comment:
hey thanks for your reply but were did the negative side lead too?Leave a comment:
Yes, that's it. Basically, I thought the cap is onnected only to one side, but there was trace from one side to other and cap was just soldered to the middle of it. I've just used short wire to connect it to the nearest joint.
It took some time to learn to be more carefoul than with 60W, but now it's quite OK. It is on the other hand wonderful for soldering in PSUs near ouput cabes (where tends to be lot of solder) or on newer motherboards with hard solder and also thick copper layers.Leave a comment:
both sides are destroyed.
so negative side.
wondering were the negative side leads too.Leave a comment:
Behemet - can you recall where the damaged trace was - perhaps mark it on a picture?
There are a couple of threads with restarting problems so might be relevant.Leave a comment:
I think I have found the problem. When changing one small capacitor, I have burned tiny path near to it. I have connected the cap to one joint of the path but didn't notice it was actually interconenction between two parts of some circuit. After joining it with piece of wire, it behaves more normally. Now I need to get some VGA cable to test it
ADD/ oh, here is one in a drawerLeave a comment:
Have you even read the thread? It works fine without CCFLs connected. Tried backlight from another display, same behaviour.
Voltage accross input capacitor is good. Problems persist no matter what capacitors I use so here is not the problem, the original ones were not the soruce of the problem. Everything now leads me to bad inverter transformers.
ADD// I've replaced input cap with no change. If it helps anything, I hear strange buzzing for all the time, except when it turns off. It comes from the main transformer.
If I disconnect one of the CCFLs on the B/W cable side, the other flashes for a fraction of second, but it seems the whole power supply stays turned on. So can it be bad transformer after all? It may be some problem on primary when the rectifier and fuse were blown, right?Last edited by Behemot; 12-17-2012, 05:42 AM.Leave a comment:
Can you try with it all connected up but with the ribbon cables to the lcd panel disconnectedLeave a comment:
You are right I thought it was white turned yellow - next step would be brown and conductive but it was never white on closer look it is a sort of semi see through lacquer. - sorry.Leave a comment:
If memory serves they should be AOP605Attached FilesLeave a comment:
Id vote for them as well
See here
https://www.badcaps.net/forum/showpo...&postcount=204
has restarting problem also, but cant read what chips you have and you did not say.Leave a comment:
You also need to remove that yellowing glueLeave a comment:
This specification for the Acer Aspire Aspire 9920 G-933G64HN can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire 9920 G-933G64HN boardview and Aspire 9920 G-933G64HN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:00 AM
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
This specification for the Acer Swift Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows 11, Silver, Intel Evo Certified) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows 11, Silver, Intel Evo Certified) boardview and Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows...09-07-2024, 03:10 AM
- Loading...
