Samsung 2253LW
  • ab101
    replied
    Re: Samsung 2253LW
    I've lost my multimeter so cant check.
    all caps are Panasonic FC.
    The start-up cap seems to have definitley worked as I didn't get blue light at all before.
    Caps not replaced:
    Far side:
    2x 820uf 25v
    1x 16v 100uf
    Inverter side:
    2x 16v 1000uf
    1x 50v 10uf
    1x 10v 33uf
    the massive cap - think its a 100uf 450v but the label is against the PCB and dont want to move it really.
    everything looks OK, no bulging or puffing. all original caps look to be Sam Young.
  • selldoor
    replied
    Re: Samsung 2253LW
    Hi - what make cap did you use for the small one - If that is on the primary side it is probably the startup cap so a decent brand/series is essential.
    With it all connected up and powered on what are the voltage readings on the connector out. Cant see the board markings -looks like 12 pins
    List them e.g.
    1 12v actual 12.3
    2 5v actual 4.7
    3 gnd
    4 dim etc etc
    To be honest there are so few caps on this board you should have replaced all of them to give it the best chance
  • ab101
    replied
    Re: Samsung 2253LW
    After swapping the 2 820uf 25v I still got nothing and realised the 47uf 50v cap had also blown - just swapped this out for a new one and now when I plug the monitor in the blue light slowly flashes and I hear a high pitched whistling noise - the back-lights don't come on however and I don't see anything on the screen.
    All other caps look OK - is there any more I can do or is this thing dead?
  • ab101
    replied
    Re: Samsung 2253LW
    are the rubycon better?
    http://www.ebay.co.uk/itm/Rubycon-82...item4ab461465a
    thanks again!
    replied
    Re: Samsung 2253LW
    They look okay. They are probably FC, but those can still be used. (Just not as good as FM or FR; those are gold print.)
  • ab101
    replied
    Re: Samsung 2253LW
    £12 delivery! ouch...
    do these look ok?
    http://www.ebay.co.uk/itm/25V-820uF-...item1c18f73fcd
    sorry - bit of a noob at this!
    replied
    Re: Samsung 2253LW
    Those look perfect.
  • ab101
    replied
    Re: Samsung 2253LW
    I would suggest you to use PANASONIC FM or FR series for the replacement. You should repalce the whole set of caps in the secondary side of the power supply at least.
    http://search.digikey.com/us/en/cat/...panasonic%20FM
    Post the pictures of the board.
    So something like this?
    http://uk.mouser.com/ProductDetail/P...dGnQq2YR4mM%3d
  • ab101
    replied
    Re: Samsung 2253LW
    I stupidly didn't take a pic of the whole board - I had to reassemble the monitor due to space. (phone quality) pic of capacitors attached.
    replied
    Re: Samsung 2253LW
    Originally posted by ab101 View Post
    I have a Samsung 2253LW that's been going strong for 3.5 years but the last few days randomly decides if it's going to work or not (sometimes pulling the plug out and sticking it back in will fix it, other times not).
    Ive got it in pieces right now and can identify 2 bulging capacitors, both are Sam Young 25v 820uf 105 degrees - I thought it would be a straight swap but having searched the forums it looks like there are a lot of capacitors that match that description!
    Could someone tell me exactly which one I need, and who in the UK sells them (trying to avoid high minimum order values but there is a maplins near me)
    Thanks in advance.
    Maplin don't sell low ESR caps, just junk caps. Farnell and Mouser are good. Some eBay sources are good, if from the UK, but avoid sources from China, as the capacitors are very likely counterfeit.
    replied
    Re: Samsung 2253LW
  • ab101
    started a topic Samsung 2253LW
    Samsung 2253LW
    Thanks in advance.
