Help needed: How to Crack Open Samsung 941BW?
  • normsuss
    • May 2012
    • 8
    I've got the base off, as well as the inverted T shaped back cover. There are three Phillips head screws holding the base holder to the monitor, which I haven't removed yet. I see four rubber plugs that the protrusions on the T shaped back cover snap into.
    How can I get the monitor apart to check the MB? I suspect I may have some bad capacitors. I'm guessing that there may be screws under the rubber plugs, but I want to have that verified (I don't want to screw them up.....no pun intended). If that isn't the way to go, I'd like some helpful advice on how to get the monitor halves separated.
    Norm
  • mariushm
    • May 2011
    • 3799
    Re: Help needed: How to Crack Open Samsung 941BW?
    I don't think you have to unscrew the base holder.
    I don't have experience with that particular monitor, but the following video may apply to yours as well:
    http://www.youtube.com/watch?v=Ul5LhuCT1y8
    Instead of knives, some use credit cards or something slightly more solid than a credit card. Some use those spatulas used in kitchen, or whatever they're called.
    (no need to use large fonts or colors, people will try to help you no matter how you write)
    • nickt1862
      • Apr 2012
      • 23
      Use a putty knife and slowly disengage the tabs.
      • normsuss
        • May 2012
        • 8
        Thanks for replying so swiftly....to both of you....
        The You Tube video was helpful, and I will use a putty knife to split the halves. I have an unused one with a very thin blade.
        Once I open the monitor, find out what has failed (most likely capacitors), and, if that's the problem, I'll replace them and get back with the results. Thanks again Mariushm and nickt1862.
        Norm
          Panasonic FM series caps:
          http://search.digikey.com/us/en/cat/...panasonic%20FM
          • normsuss
            • May 2012
            • 8
            budm...
            Thanks for the info: "Panasonic FM series caps:
            Norm
            • normsuss
              • May 2012
              • 8
              Removed the PS. Sure enough...it's full of CapXon capacitors. Some are bulged. Looks like Samsung joined many others by installing some of the crappiest capacitors. I'll replace them with quality and report back.
              • nickt1862
                • Apr 2012
                • 23
                Yeah, of the various Samsung LCD monitors I opened up they're full of CapXon, Sam Young and "xyz" branded chinese crap caps.
                Best to replace ALL of the caps.
                  Samyoung and Samwha are actually Korean. They are still crap though.
                  • nickt1862
                    • Apr 2012
                    • 23
                    Yep crappola - lol!
                    I don't even love SAMXON, tells you how picky I am.
                    • normsuss
                      • May 2012
                      • 8
                      Thanks to all of you for your generous help
                      . Without it, I couldn't even have figured out how to crack the case. I've replaced the caps with Panasonic...at least I think so. Well, anyway the monitor works like new.
                      The reason I write "I think so" is because some of the caps don't have the Matsushita "M" logo on them. The "T" vent is impressed on the top. There is a silver stripe with the Panasonic type minus signs on it. But, there is no name or logo on any of them. Other than the specifications, 1N30TK is printed on the side of a 1000μF, 25V,105ºC FR capacitor. So, I wondered if some are counterfeit. Does anyone have a clue as to whether they are likely to be genuine Panasonic caps?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        If you got the Panasonic FM/FR from digikey as budm recommended, then there is no need to worry. If you went on ebay, then you probably got fakes.
                        --- begin sig file ---
                        --- end sig file ---
                        • mariushm
                          • May 2011
                          • 3799
                          They're Panasonic, Matsushita is the "mother company" and T is their top... FR series is black with silver line so everything sounds good.
                          • normsuss
                            • May 2012
                            • 8
                            Thanks for your helpful response, mariushm.
                            A few days ago, I e-mailed Vince Pastor, Sr. Product Specialist - Aluminum Electrolytic Capacitors - Panasonic. I got a response from him yesterday. He verified what you said, and also said that some of the Panasonic caps don't have the "M". So, it looks like I'm good to go with genuine Panasonic caps.
                            • normsuss
                              • May 2012
                              • 8
                              Nope! Not e-bay. Panasonic says that's the normal configuration for those caps.
                                09-07-2024, 05:50 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 06:20 PM
