Acer x241w capacitor saga
  • hornplayer6
    • Mar 2012
    I have a five year old Acer X241W 24" lcd monitor which started acting up about a month ago - the screen would flash on and then go blank, etc. Did some googling and found this forum and discovered the capacitor issue.
    We opened it up and indeed found several bulging capacitors. I ordered a replacement kit and my dad replaced them all for me. Monitor worked great, but after using it for about 2-3 hours I heard a loud crack. Then, nothing happened, no smoke or odor, the screen looked fine, etc. I thought maybe the noise came from the plastic case adjusting itself or something. Continued to use the monitor for another half hour or so.
    A while later I came back to the computer and attempted to bring the monitor out of it's power save mode, and all I got was a dark screen with some bluish vertical bands and a few pixel wide red and green lines.
    My dad reopened the monitor and saw no obvious problems or scorch marks, finally discovered two small blue ceramic capacitors on the power board that have hairline cracks indicating they had split open.
    So, would that be the cause of the dark screen? Fixable? I'm curious about the delay between the cracking sound and the screen failure. Maybe these events are/are not related? I know nothing about this stuff, so I'm just throwing this out here to get some ideas to see if it's worth trying to repair.
    https://www.badcaps.net/forum/attach...1&d=1336097449
    Re: Acer x241w capacitor saga
    Those capacitors are for the snubber circuits to protect the MOSFETs that drive the power transformers, its function is to clamp down high reverse voltage when the MOSFET turns off, without it, the MOSFET can be damaged. Can you remove them and take good pictures so we can see the values?
    • hornplayer6
      • Mar 2012
      The numbers on both of them are:
      RR
      102K
      1KV
      60
      • jetadm123
        • 2169
        RR
        102K
        1KV
        60
        That's a ceramic cap that's rated 1000pf 1KV +/-10% tolerance:
        http://search.digikey.com/us/en/prod...102-ND/1021052
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
          by momaka
          03-15-2023, 10:17 PM
        • maralexbar
          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
          by maralexbar
          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
          If anyone knows how to force the external monitor as primary for Notebooks of those models
          11-02-2024, 09:18 AM
        • ADV
          Acer Ferrari F-20" monitor display interference and replacement capacitor selection
          by ADV
          Good day everybody
          I hope I'm posting in the right section - I am new to this awesome forum.
          I have received an ACER Ferrari F-20" LCD Monitor to repair.
          It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
          For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
          I opened the external 18V power supply and see no bulged capacitors...
          11-02-2021, 09:32 AM
          09-06-2024, 05:27 AM
