Re: Samsung 912N Problem
Hi Budm,
Thank you for the schematic diagrams. I have printed them out and taken a look but was unable to find reference to BL_ON. I did, however, see BL_EN on a few of the pages.
This is my first time reviewing schematics for this monitor; could you offer me some guidance on how to locate what I am looking for? And then I can give it a try this evening, once I'm home from work.
On another subject, I am in the final stages of assembling my Blue ESR meter. It was a lot of fun and my seven year old was an eager helper. Maybe he will take it to science class and impress his friends.
Thanks all once again.
You may want to check the BL_ON signal line to see if it changes when you have the monitor connected to the PC, I have a feeeling that the BL_ON changes when the PC is connected.Leave a comment:
A quick update on my 912N project...I replaced the dual channel mosfet on the logic card this weekend, and it is still not working properly. The problem persists in that, with no pc connected, I get a steady green indicator light, and the 'Check Signal' box moves around the screen freely and does not turn off, albeit the box does not appear uniform (see photo above) but then once I attach the pc video source, using several different cables, the video goes completely dark. The difference is now, since replacing the mosfet on the video card, I can get the Check Signal box to appear for a few seconds first.
I'm thinking that on the inverter board, there is a mosfet hidden on the underside of a smaller circuit board. Hopefully tonight I can post photos of the inverter board, and at that time I would like to ask the group if they recommend me to remove the little attached circuit card and test the mosfet under it.
Thanks as always.Leave a comment:
http://ccfldirect.com/blowoutlamps.html
Shipping is $3.99 for USA customers.
The pre-harnessed ones are really nice and easy to replace.
Give them a call or send them an email.
2) I know budm has an entire stack of them from his volunteer job at the recycle facility.
https://www.badcaps.net/forum/showpo...2&postcount=32Leave a comment:
Here's an example. Plasma TV, dead. No 12v. Unplug the Z sus board and the 12v is fine. Is it the Z sus shorted, causing the 12v to drop, or is it the power supply unable to supply the Zsus?
Quick easy test, clip an 1157 on the power supply with the Zsus disconnected. If it lights bright, and the 12v stays stable, bad Zsus.
Though technically you could measure the resistance of the 12v inpit to the Zsus and see it's shorted, but that's an example.Leave a comment:
That's interesting smason. When you put a load on a bad 12v power supply, what happens? Does the reading go way down? Pop a fuse?
Also, can anyone recommend a source for a Samsung ccfl wire assembly for testing purposes? Digikey? Mouser? CCFL Warehouse?Leave a comment:
I often use one just to see if the supply can handle a load, sometimes the 12v supply will measure fine, until you put a load on it.
Really the best substitute for a suspect CCFL, is a known good CCFL.
Now and then I get an unrepairable monitor (broken screen, MCU made from unobtainium) and I'll keep the CCFLs for testing.Leave a comment:
This good advice Retiredcaps. I also watched the Youtube video last night - that guy is really good at what he does and my big takeaway was flux, flux, flux.Leave a comment:
At 58 cents, I would get 2 since it is your first SMD solder attempt. If all goes well you will have a spare.Leave a comment:
Oh, my I finally get to use my coupon!!!
I will also be ordering an NPN transistor to calibrate my soon-to-be-arriving Blue ESR tester kit. My bill just doubled.
Thanks Retiredcaps. Your insight is very much appreciated. I will get back to the list as soon as I make the repair and will report how it went.
LAS.Leave a comment:
http://search.digikey.com/us/en/prod...ACT-ND/1849924
or Newark for 59 cents + 15% off
http://www.newark.com/fairchild-semi...6?Ntt=FDS9933A
2) I like this video for soldering SMD (short 9 minute video)
http://www.youtube.com/watch?v=3NN7UGWYmBYLast edited by retiredcaps; 04-05-2012, 08:25 PM.Leave a comment:
S1 and G1 measure .2 ohms;
S2 and G2 measure .3 ohms.
The two D1 pins look like they are joined together on the schematic, as do the two D2 pins.
All measurements are done with the chip out of the circuit and on my dining room table. It was also the first smd component I have ever removed from a board, and it went easier than I expected. Putting it back is another matter, but I'll get it in.
Looks like two shorts, yes?Leave a comment:
Test this mosfet for shorts. See section 2 Shorted Transistors/MOSFETs
https://www.badcaps.net/forum/showpo...4&postcount=19Leave a comment:
IC600
A43AG
FDS9933A
I googled each number, and while I came up with a part # for A43AG, the package didn't match. I googled FDS9933A, and it looked more like the part on the board. Datasheet is attached below. A dual channel 2.5v specified Power Trench MOSFET. Finding myself on a roll, I took some voltage measurements using a mounting screw as a ground point:
Pin 1 S1 12.4
Pin 2 G1 12.4
Pin 3 S2 5.0
Pin 4 G2 .5
Pin 5 D2 5.0
Pin 6 D2 5.0
Pin 7 D1 0
Pin 8 D1 0Attached FilesLast edited by LAS; 04-05-2012, 07:35 PM.Leave a comment:
As to IC201, I did a little online research as well as here on Badcaps, and it looks like it cross references to 24C08 if I'm not mistaken. With that, I was able to find a datasheet and this is what I found with the black probe on pin 4 Vss (ground):
1 less than 1v
2 less than 1v
3 less than 1v
4 Ground
5 SDA (Serial Address/Data IO) 5.11v
6 SCL (Serial Clock) 5.1v
7 WP (Write Protect input) 5.11
8 Vcc (+) 5.11 and spec calls for 4.5-5.5
I'm not familiar enough with this package to know if it's good or bad, but should the whole top row all be at 5.1v?Leave a comment:
IC601 (APL5522)
Pin 1 3.3v
Pin 2 4.25v
Pin 3 4.2v
Pin 4 2.5v
IC201
A81SC
C423Leave a comment:
1) IC601 is APL5522. Datasheet is attached
2) Measure pins 1-4 while using pin 7 for GND (black probe).
3) Report readings.Attached FilesLeave a comment:
Heatsinks are likely live. Since your power mosfet is probably attached to that heatsink, it will register high voltage.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
