Hyundai L90D - No OSD
  • TXShooter
    • Mar 2012
    I've searched the forums using "L90" as my search string and found only one entry not related to my problem, so if this has been covered, I apologize in advance.
    My monitor was working fine until I moved. I used the original box the monitor came in for the move.
    Symptoms:
    Unit powers on and stays on, backlight does come on, "Menu" does not show, and no video appears from known good source. Tapping the back of the unit smartly causes a "white flash" on the screen. Disconnecting the SVGA cable yields a blue screen after a minute or so. I do not own a DVI cable to test that input. While connected, the unit does sense a video presence as the LED stays green until I shut down the PC, then it changes to amber.
    It's been 12+ years since I've repaired consumer electronics, and LCD screens were a dream to own at the time.
    Any ideas on where to begin troubleshooting on this one?
    Many thanks,
    TXShooter
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Hyundai L90D - No OSD
    I would take it apart, clean and reseat all the connectors. If that doesn't work, then post clear focused top down view of all your boards following my sig file below EXACTLY.
    --- begin sig file ---
    --- end sig file ---
    • TXShooter
      • Mar 2012
      Cleaning the connectors worked!!!! Thanks!!!
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • DrDos
        Unit runs but no speaker output kenwood KR-6030
        by DrDos
        I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
        09-14-2025, 09:57 PM
      • nobbnobb1
        Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
        by nobbnobb1
        Hi guys,
        Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
        When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
        02-03-2022, 11:14 AM
      • Gjackson
        Air-conditioning unit power supply failing to power up
        by Gjackson
        Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
        01-08-2022, 09:24 AM
