I bought new keyboard and fortunately its perfect. Unfortunately It was an easy fix. Wanted it to be a difficult fix so i could learn a lot. I still learned something thanks to you all especially retirecaps and jasgriff. My next attempt will be an lcd tv. Will have to look on craiglist for a broken one.
I assembled the monitor and hooked it up to computer and it worked. But typing is not working which am thinking might be the keyboard. I might have damaged the broad flat cable with connector to the lcd when i was disassembling them. Apart from no typing, everything is perfect. Will change keyboard today to test.
Amazing the power light(blue and amber) came on or worked when i plugged it into the power bar. Before there was no light or the monitor would not response. I didnt do anything to it. All i did was remove F801 and soldered it back. Hmm whats going on? Do you think its advisable for me to assemble the monitor with the lcd screen and try if it will work.?
I also found some solder joints that were never soldered and I don't know if it was accidental or intentional by the manufacture. I have attached a picture of it. It will be weird if accidental though.
Anyway I did the voltage readings on CN801.
1 VCC5V=5.04V
2 VCC5V=5.04V
3 GND=0.00V
4 GND=0.00V
5 ON/OFF=55.9mV-56.0mV
6 BRIGHT=26.1mV-26.4mV
7 VOLUME=26.2mV
8 MUTE=0.646V
3) I suggest plugging your lcd into a power bar so that it can be turned on/off with a switch. This is because you had a burning smell and we want to cut power quickly if needed.
4) Put your black probe on a ground screw. I usually use the one closest to where I am measuring. Some people use the chassis. This is your cold ground.
Put your red probe on each one of the 8 colored pins (CN801). Set your Amprobe to measure DC voltage. Everything will be low voltage since you are on the cold or secodary side.
Not sure what is going on with your pictures I can only suggest using a different browser to see if that helps. Oh and make sure that you are using the manage attachments button.
I will appreciate if you can show me the mosfets and bridge rectifiers so i can test them. Thank you
