Samsung SyncMaster Model 731N Distorted Display
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung SyncMaster Model 731N Distorted Display
    Okay now I understand. Some old sound cards might have fixed 1.8V regulators.
    --- begin sig file ---
    --- end sig file ---
    • trains58554
      • Apr 2012
      • 55
      I will look at our old sound cards. I think we may have a few of them yet.
      Thanks for your help.
      • retiredcaps
        • Apr 2010
        • 9271
        I found one on an old sound blaster here at home.
        • trains58554
          • Apr 2012
          • 55
          We only had two or three sound cards left and none of them had the chip.
          • trains58554
            • Apr 2012
            • 55
            @retiredcaps would a 6206a 18 work?
            Jay
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              6206a is a voltage regulator from the datasheets that I have seen and 18 is denoting 1.8V DC so it should work.
              • trains58554
                • Apr 2012
                • 55
                well I think that chip would have worked if I would not of broken it. Oh well I guess I will just keep picking though the bone yard and maybe get lucky again.
                • trains58554
                  • Apr 2012
                  • 55
                  Will the TLV1117-18CDCYR work?
                  Thanks for all your help.
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    TLV1117-18CDCYR data sheet
                    • trains58554
                      • Apr 2012
                      • 55
                      Hi
                      Thanks for your reply I have looked at the data sheet and as far as I can tell it should work.
                      • jetadm123
                        • 2169
                        #31
                        Hi
                        Since you have access to the data sheet, you can test out the regulator by hooking up a 9V battery to the input and measuring the output with your meter. You should read 1.8V.
                        • trains58554
                          • Apr 2012
                          • 55
                          Hi All,
                          Thank you everyone I got my replacement voltage regulator and installed it now the monitor works just like it did when it was brand new.
                          Thank you everyone.
                          Jay
                          • Jasgriff
                            • Feb 2012
                            • 578
                            Well done Jay.
                            Thanks for letting us know that its worked out ok for you.
                            Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                            How to resize your pictures guide click HERE
                            Retiredcaps Ideal post example click HERE
                            • lti
                              • May 2011
                              • 2553
                              Has anybody tried to figure out why this regulator fails? I have one of these monitors with no backlight (a completely unrelated problem), and I want to make sure I don't have any other problems once I fix the inverter. Is it just a cheap, low-quality part, or is there something else that will make even a name-brand part fail?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Vizio TVs seem to have a lot of problems with bad voltage regulators. While I'm no design pcb engineer, I suspect it is a combination of lowest possible cost parts and poor circuit design.
                                The regulators could be failing because they are designed without any "support" components or they are cheaper to use versus something more expensive.
                                • lti
                                  • May 2011
                                  • 2553
                                  The circuit design is really strange. I could see Samsung screwing up the circuit design that badly. For some reason, they put random diodes in parallel with components in the inverter where diodes are not needed.
                                  The regulators on my board are out of the 1% tolerance (1.76V for the 1.8V regulator and 3.25V for the 3.3V regulator), but they are probably a cheaper version with wider tolerances. The board still works perfectly.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    Some datasheets I have seen say 2% is still within specifications.
                                    The tolerance also depends on how accurate your multimeter is. Today's cheapest multimeters have 0.5% DCV accuracy and most of them use the Intersil 7106 chip or some variation. How long the cheap ones stay within the 0.5% is the key question.
                                      09-07-2024, 05:50 AM
                                    • soopacrucial
                                      by soopacrucial
                                      Hi folks,
                                      10-29-2024, 02:40 PM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
