Emachines L22YCET Bad Cap symptoms, but no sign of bulging caps.
--- begin sig file ---
--- end sig file --- -
Re: Emachines L22YCET Bad Cap symptoms, but no sign of bulging caps.
I would change the caps first before investing anything in it... Those two small caps you said you didn't list, those are important to. I'm a little busy putting a BOM together for a bunch of stuff I have to fix, I'll try to help you after.
Who do you use, Digikey? (I don't know why Digikey is such a ripoff lately. Newark has WAY better prices lately, and they have lots of Nichicons at promotional prices now).Comment
Wonder what caused CCFL blowout. I think I checked my LCD, it shows 5000 hours in the service menu... I wonder if this also counts time in standby... Di you use this heavily?Comment
Heres the Left and right side of the CCFL
Left side pic is a bit fuzzy, but from the right side pic, you get it.
Yes Its been heavily used for 3 years. Standby mode ftw! It _is_ Emachines, so I can see something failing.
An afternote: I have an old 17" Syncmaster from 2002 that is still running strong -- not even 1 dead pixel. /knocks on woodLast edited by Spz0; 01-25-2012, 06:27 PM.Comment
So, my next logical question is: Where would you go for a replacement? Im reading that they can be sold pre-harnessed or bare. I dont mind a little soldering, but if its not too much more cash to get a pre harness one then I would go that route.
Insight?
Thanks again for all the input!!!Comment
These guys have the best selection from what I have seen:
http://www.lcdparts.netComment
Great thanks!
Took a quick look at it, seems they dont have pre-harnessed CCFLs for 22" monitors, so I'll be soldering it myself.
With the bare CCFLs, the charge is for one single tube, not the 2 correct?Comment
Hehe, I have no idea... I encountered this website when I was looking for a bulb for a really old Panasonic 4:3 LCD. Never ended up ordering from them because I have to do what you did and make sure the problem is with the bulb in the first place... The TV had all Jap caps inside so I suspected the bulb, but you never know.Comment
I ordered some ccfls from ccflwarehouse.com not too long ago. I actually ordered them through e-Bay (they sell under the name plazmo_industries). The bare ccfl is $8.00 with $4.99 shipping. I just measured the diameter and length and put that information in with the payment to them. The shipping cost is constant with 1 or more ccfls. The ccfls arrived in just a few days and worked great after I got them soldered in place.
http://www.ebay.com/itm/250474949765#ht_1047wt_1163Comment
Thanks for the links. Im gonna check them out today and get something on order.
Im wondering - since I now have it disassembled, if I should replace both top CCFLs, since they are on the same circuit, or just the one -- or all of them for that matter?
(*edit: I will be buying 2 now, as the dis-assembly process cracked the 2nd tube =\ )
Any suggestions?
afternote regarding CCFL tests:
When I tested #'s 2, 3 and 4 They all lit up individually and produced "2sec to black" conditions. and #1 was obviously blown out. When testing CCFLs, is it normal for the 2sec to black condition when testing individual CCFLs (monitor detects incomplete circuit and shuts off CFLs), or _should_ they stay permanently on when testing? (hope I explained myself correct). Im asking because I am trying to figure out if there is anything else going on that would cause the 2sec to black condition.
Thanks!!Comment
Any suggestions?
Thanks!!
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Replacing 1, 2, 3, or 4 ccfl's is mostly a question of economics and preference. You're looking at about $40 to replace all of them, $15 to replace just one. If the other ones were showing signs of needing replacement, it would definately be worth while in replacing them.
Yes, turning the monitor on with just one ccfl plugged in will result in 2 seconds to black as this situation will trip the sensing circuit and shut down the monitor. The reason retiredcaps in post #21 asked about the ccfl's result in a different connector was to determine if something was wrong with the ccfl / wiring or with a particular connector.Comment
Excellent -- I _thought_ there would be some type of sensor to detect faults in the CCFLs.
@Jayoung - I just purchased 2 of the 2.2mm 475mm Full Spectrum CCFL bulbs from the ebay store you listed. Thanks for that. $21 isnt a bad price at all!!
I'll let you all know when they come in.
Thanks again!! Everyone has been extremely knowledgeable and helpful in helping me diagnose my issue.Comment
If you bought the "bare" lamps, there is a tutorial at
http://www.ccflwarehouse.com/lasotu.html
This is a very fragile procedure so proceed cautiously and slowly.
About 50% of the people who try break their replacement lamps because they are impatient and try to force things.--- begin sig file ---
--- end sig file ---Comment
Aye yes. I've read that page, thanks for the link.
Im a very patient person, so I will definitely be cautious.
I tore down the CCFLs wire harness the other day -- took me about an hour due to the heat shrinked rubber around the wires going into the end cap. Had to carefully slice it off so I could pull enough slack in the wires to free the assembly from the channel.Comment
by re-atariI have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...-
This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-12-2024, 03:36 PM
by Per HanssonI have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
As I find linear high voltage regulator designs interesting I drew up the attached schematic... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
