iMac G4 17": black screen, backlight works
  • blargg
    • 51
    I bought an iMac G4 1.25 GHz (one with built-in LCD) for a discount because the LCD just shows glowing black. The backlight works, and can have its brightness changed. Computer has on-board video and VGA out works fine. LVDS cable to LCD looks fine on motherboard, and socket solder joints to motherboard look good. Unplugging it results in OS not detecting LCD, telling me that the cable is at least partially connected to panel. I have yet to get a 1.5 mm hex to open the panel's case to see whether LVDS has come unplugged there. I've done all the Mac-specific NVRAM and PMMU reset procedures, as did the previous owner.
    Any ideas what could cause a panel to be black? It's my understanding that this indicates that the LCD drivers must be getting power, otherwise it'd be all white, but maybe some are "inverted" and all white only when totally driven. The OS doesn't turn on backlight when LVDS is disconnected, so it's hard to tell what "color" it is when unpowered.
  • Toasty
    • Jul 2007
    • 4171
    Re: iMac G4 17": black screen, backlight works
    Loosen the tiny Phillips head screws on the connector from the panel to the mainboard. Play gently with the connector and see if any changes occur in the display while doing so. I had one where the wiring to the connector was intermittent. Gentle pressure or twisting would cause it to come on or blink/flash.
    If that doesn't work, it's time for a new panel.
    You're getting all 3 green LEDs, yes?
    Please fill out your location in your forum profile.
    Toast
    veritas odium parit
    • Toasty
      • Jul 2007
      • 4171
      If you need the screen, the part number is 875-2052-C.
      Flea Bay has a bunch up right now. Make sure the seller has a non-DOA policy and covered by Buyer Protection.
      Here's one:
      http://cgi.ebay.com/ws/eBayISAPI.dll...m=220926714217
      Toast
      veritas odium parit
      • blargg
        • 51
        Not sure what three green LEDs you're referring to. This is the iMac G4 with the half-sphere base and separate LCD panel connected via a really adjustable silver supporting arm ("flower power" Mac). It's not worth replacing the panel if it's bad; an external monitor works fine. I only paid $75 for the computer. I'm hoping it's just an unplugged cable once I get in there. Thanks for the link to a panel, which is useful in case I ever change my mind.
        I tried filing a hex wrench down just a hair (English versus metric, ugh) but rounded it a bit and may have stripped the hex screw in the panel. Once I get a proper 1.5mm hex wrench I'll know. In the mean time, I plugged the panel back in and tried pressing on the back and moving the supporting arm all around to see whether that would jiggle the connection any. Black the whole time.
        • Toasty
          • Jul 2007
          • 4171
          Sorry! My bad. Have no idea on these units.
          Panel link was for the iMac G5 AIO unit. Newer than yours.
          veritas odium parit
          • blargg
            • 51
            I finally got the hex key to open the panel and tried unplugging and plugging back in the TMDS connector to the LCD, but no change. I verified that each line connected to the other end, so the cable seems good. I verified 3.3V to the LCD as well. With the computer on I did try unplugging the TMDS to the LCD, which made the screen go from glowing black to bright white (backlight is powered separately). That's further evidence that the LCD is getting proper power and intentionally making the LCD black. At this point it looks like it probably won't be worth any further time, as the next steps would be more involved (disassemble panel to check LCD AC voltages, figure out whether it's getting a valid TMDS signal, perhaps by connecting DVI connector and trying to run a normal display off it). I was hoping this was a common enough problem that the fix was well-known. I have a hard time accepting that the LCD driver just failed, or that the TMDS signal driver failed, but not all failures are simple loose connections or bulged capacitors, sadly.
            • Toasty
              • Jul 2007
              • 4171
              Keep an eye out for local school disposals/auctions. I saw these going for $40 a piece 3 years ago...
              Craigslist?
              veritas odium parit
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • VcemPzd
                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                by VcemPzd
                Hello everyone !
                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                04-28-2025, 10:14 AM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • withalligators
                Yet another Samsung 305T post - black screen w/backlight, occasionally works
                by withalligators
                Hey folks,
                I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always...
                03-25-2022, 11:24 AM
              • Francesco Valsecchi
                r9 290 "black screen"
                by Francesco Valsecchi
                hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
                08-18-2025, 06:44 AM
