Help with a Compaq WF1907
  • Kveld
    • Jan 2012
    I did a search of the forums, googling the issue is actually what led me here, and i have similar issues as the other poster but it behaves different then his so i figured i would start a new thread just to be safe.
    The issue im having is that the monitor will work fine for a while then starts doing the "2 seconds to black" thing sometimes five or ten minutes later it will stop doing that and start to work fine and stay working for anywhere from a few minutes to a few hours and then start to go out and other times it might be a few hours before i can get any use out of it again.
    I tried the flashlight test and decided it was a bad inverter board but in the other post they mentioned it could be something causing the board to turn itself off as a safety feature and since mine works fine sometimes but acts up other times i wasnt sure.
    Anyone know if this would be an easy fix for someone with no soldering skills, or would i be better off to just call it dead and get a new monitor?
  • Kveld
    • Jan 2012
    Re: Help with a Compaq WF1907
    Oh should also mention that there is no noticeable dimness or discoloration, but right before it goes black the screen flickers for a couple seconds.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Hi - Its not going to be real easy if you have never soldered anything before. You can of course practice. Do you have a soldering iron solder flux etc. Do you have a multimeter?
      If you dont have these you would need to decide if their cost is worthwhile if you are just fixing one item as against starting a new hobby.
      How long can you do without this monitor? have you another you can use.
      You will need to dismantle the monitor and post clear pictures of your boards using the manage attachments feature.
      You will also have to be very precise in what you are saying.
      I am not sure from what you say that you have understood the "2 seconds to black" problem - have you read the thread titled "A guide on how to troubleshoot 2 seconds to black" in these forums.
      You say "The issue im having is that the monitor will work fine for a while then starts doing the "2 seconds to black" thing sometimes five or ten minutes later it will stop doing that and start to work fine and stay working for anywhere from a few minutes to a few hours and then start to go out and other times it might be a few hours before i can get any use out of it again."
      "2 Seconds to black" really only relates to switching on a monitor which usually ( but not always)flashes briefly then goes black within a few seconds of switching on.
      It is not something that happens after 10 minutes or a couple of hours and I have never seen it correct itself after 10 minutes.
      It could be any number of other things. Faulty components which would need testing/replacing - faulty circuits - dry/cold solder joints that open close with heat.
      Have you done any simple initial tests - using it with the back off or with a fan on it to try to keep it cool.
      Have you tried it on another computer / laptop for several hours. This is to see if the problem is with the video card or even the pc power supply.
      Random blackouts can be difficult to diagnose, I am no expert but my hunch would be that one or more of the CCFL lights in the monitor is going or where it is soldered to the connector wire is burning out. This will evenually lead to "2 Seconds to Black"
      If you read: https://www.badcaps.net/forum/showthread.php?t=13853 it will give you some idea of what I am talking about.
      • alexanna
        • Mar 2010
        • 1346
        ^ Selldore,
        you get no argument from me,I also would suspect a wiring problem to one or more of the CCFLS.As the panel heats it aggravates the wiring problem.
        The top CCFLS have been giving me the most problems; the wiring is oxidizing inside the silicone insulation. Slight discoloration at the ends of the CCFL tubes is normal as the CCFL ages.
        About the only way I know to verify if that is the problem is to substitute 2 good bulbs, and let her run to get hot.
        If wiring is the problem always strip about an inch of insulation off to get to good wiring.
        • Kveld
          • Jan 2012
          I understand that "2 seconds to black" is an issue where you turn the monitor on and then a few seconds later it goes black but with the power light still on. Ive tried it on multiple PCs and its the same deal.
          The only thing that keeps me from thinking that its as simple as swap out an inverter board or something is the fact that it doesnt do it all the time. It set in a corner in my room for about 3 weeks and i hooked it up last night and it lasted just a few minutes before it went black. went and ran errands for a few hours and came back and got a good hour or two use out of it before i unhooked it and put my monitor back in place.
          It seems to me that the problem would be simple enough to fix, i just have to track it down and would hate to send a monitor to the scrap heap if it can be saved with a small bit of effort and a few parts. Ive never attempted doing actual repair on hardware besides tracking down a faulty part in a PC and swapping it out, but i have a few friends i can learn soldering from so i would be willing to pick it up as a hobby and to add a new skill to my repertoire. If it turns out that this is going to be pricy, by pricy i mean in the 50$ or higher range since i can get a new one for 85$, or more complicated then i imagine then ill probably scrap this project and see if i can find someone that wants the monitor for parts or to fix.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            As you see Alexanna also seems to think it might be CCFL wiring but without pictures there is no way we can tell.
            Did you read the post
            https://www.badcaps.net/forum/showthread.php?t=13853 ?
            • Kveld
              • Jan 2012
              it will be a few days before i can get pictures. will probably be around Tuesday or Wednesday before i can crack teh case open and take a few pictures for you all.
                HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:44 PM
                HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 03:36 PM
                HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-12-2024, 03:30 PM
                HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
