question about panel replacement
  • merkin
    • May 2010
    • 57
    Just received a Dell ST2220Lc.
    Unfortunately it has a cracked screen.
    The panel is a made by LG LM215WF4(TL)(A1)
    I am searching for an inexpensive replacement, used or new.
    During the search I found this... h++p://www.ebay.com/itm/SAMSUNG-LTM215HT03-21-5-LED-LCD-Full-HD-Pull-Dell-ST2220-/110800661328?pt=LH_DefaultDomain_0&hash=item19cc3beb50#ht_1555wt_1026
    So Samsung made panels for this Dell model also.
    1. Does anyone know of any other panel manufacturers for this model?
    2. Or any other monitor manufacturers using these panels?
    Thanks in advance for the tips.
  • NolesFan
    Can LED panels be used from different TV's ( or the internals to the panel )?
    by NolesFan
    I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
    06-23-2025, 09:19 AM
  • JayFixesIT
    LG 65UH9500 TV Panel replacement seal?
    by JayFixesIT
    I am in the process of replacing the backlight boards on the LG 65UH9500 TV. It requires the separation of the front glass/panel to get to the boards. The panel is help on to the frame with some kind of strips that I cannot reuse to adhere the screen to the frame. Anyone have any experience/Ideas on what I can use to securely hold the 65" Panel to the frame. I would hate for the panel to fall face forward. Thank you in advance....
    09-08-2024, 11:15 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • triplefour
    SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
    by triplefour
    TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
    tcon is built into mainboard.
    Only one cable goes to panel boards.
    there is a cable from one panel board to the other that links them.
    cost cutting measure that results in us having harder time to diagnose.
    removing the link to the second panel board allows TV to stay on with stable backlight but no image.
    used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
    07-28-2022, 07:59 PM
  • Storyteller12
    QN55Q60R Service Menu Panel Help
    by Storyteller12
    I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
    I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
    I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
    the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
    01-13-2024, 01:57 PM
