Samsung t220hd buzzing sound after repair
  • cronogr
    • Nov 2009
    • 6
    Today i fixed my old lcd monitor (2sec to black problem), replace 2 ccfl's that wer bad, the inverter and all the capxon caps with lets say Panasonic caps, i dont trust my local shops but this was all they had ! So now the monitor is working fine but whenever i try to change the color tone from dynamic to typical or movie mode the monitor is making a buzzing sound this also happen when i lower the backlight and some other things to the menu. The monitor is working fine only under dynamic mode :/ Im too tired to reopen it right now but the sound is definitely coming from the psu so probably something is broken there is ther a possibilty that the new caps are making this ? I dont have the old ones to try them :/ but i will try to purchase sometime soon quality brand caps. Can anyone give me an idea as what the culprit might be ?
    Thanks in advance
  • cronogr
    • Nov 2009
    • 6
    Re: Samsung t220hd buzzing sound after repair
    I just disassemble the monitor, and found out that the noise is coming from the 2 ccfls i changed but now with the case open the noise is decreased to a minimum. Any ideas ? should i change the wiring (do i need a special type of wire or a wire with similar thickness will do? Or this indicates an even greater problem ?
      09-07-2024, 05:50 AM
      by momaka
      03-15-2023, 10:17 PM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
