Dell 2208WFPf completely dead +another..
  • SignatureSeriesOwner
    • Dec 2011
    • 4
    I figured it would be best if I joined a forum specializing in computer/LCD monitor repair, versus posting about it on a radio forum!
    My current problem is with two monitors. One, a 22" Dell 2208WFPf does not power on at all. I will plug it in, and it does absolutely nothing. All of the capacitors look good, none of them are swollen (which is a pretty common problem for anything made in the last 10 years) and I don't recall there being a fuse on the PCB, but I may be mistaken. I'm a bit of a "noob" with troubleshooting anything that doesn't require vacuum tubes to run, but I did recap a 20" Acer monitor I have. Any suggestions on what I should look for/at? It's a very nice monitor, I'd hate to "toss" it if I can fix it.
    The other monitor, a 19" eMachines monitor, powers on, but only displays a solid white screen. Not sure what the cause would be there. No bloated capacitors, so I don't think the problem lies there.
    Thanks guys!
    Good to meet you all
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell 2208WFPf completely dead +another..
    1) Post clear focused top down view pictures of your boards following the instructions in my sig file below. Please do not post inline.
    2) If you have a multimeter, see if there are any secondary DC voltages on the connector between the power board and the logic/main board. At least one of the voltages should be 5 V DC.
    3) There should be fuse next to the AC plug. It will be marked on the pcb with "F" for fuse. Maybe something like F100. A good fuse should measure less than 1.0 ohms.
    3) Start another thread for the emachines. It gets confusing having 2 monitors in the same thread. Post pictures of this too in the new thread.
    --- begin sig file ---
    --- end sig file ---
      • Dec 2011
      • 4
      No problem!
      I will post pics tomorrow, too tired to go out there now.
      Two more questions, if I may:
      "Secondary DC Voltages" I suppose, in order to test this, I'll need to remove the boards and plug the P/S board in to test this? I can't see there being any voltage when it's not connected to power.
      As far as the fuse, will I need to remove it from the circuit to test, or can I simply hold a lead to each end connector where it connects to the PCB to test?
      Thanks!
      • retiredcaps
        • Apr 2010
        • 9271
        Correct. All boards need to be plugged in with power ON. Most secondary voltages will be less than 24 V DC. The hot side, however, might be as high as 335 V DC if there is PFC involved.
        So we will measure the "cold" side first. Use a ground screw on the cold side for your black probe. On some boards, there will be a legend telling you want to expect on a per pin basis.
        If all secondary voltages are 0.0 V, then we need to measure the hot side.
        Test it in circuit. All resistance measurements are done with lcd unplugged and power OFF.
          • Dec 2011
          • 4
          Hi there, just an update, I haven't forgotten, I just haven't been able to spare the time to disassemble these again to take photos yet. Heading to Florida tomorrow, and I'll be there for a week, so after that, I should have a little time for some troubleshooting.
          Happy New Year everyone!
            • Dec 2011
            • 4
            Alrighty, here are pics of the P/S and video board on the DELL.
            The fuse measures 0.6 Ohms, so I assume that is good. None of the capacitors appear to be swollen, and I do not have a ESR tester to test them in circuit. Nothing appears to be burnt or look out of the ordinary.
            I'm sorry, but I should have said this earlier....how do I measure the secondary voltages? (as in, where?) If you can point out where I should be poking around, I can check it out with my multimeter. Will both boards need to be plugged in, and flipped upside down for me to check the pins under the boards, or is there another method? I would think that if they weren't "grounded" to the frame with the few screws holding them on, they wouldn't read anything, with no ground.
            EDIT:
            IT appears I cannot add pictures. "A security token is missing."
            • senndogg
              • Dec 2011
              • 383
              • Albania
              what kind of browser are you using? can not you disable the firewall only just the moment of uploading?
              • PlainBill
                • Feb 2009
                • 7034
                EDIT:
                That message indicates the picture is too large - the board limit is 2000 pixels in either dimension. My preferred tool for cropping and resizing pictures is VuePrint, available free here. Note the serial number.
                PlainBill
                • Borse2008
                  Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                  by Borse2008
                  Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                  I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                  • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                  • There’s
                  07-15-2025, 04:55 AM
                • max-power
                  Dell E6540 laptop completely dead after dssasembly
                  by max-power
                  Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                  that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                  After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                  03-24-2025, 08:49 AM
                • diamon
                  Dell Latitude 5520 completely dead
                  by diamon
                  I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                  Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                  After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                  Have checked with a thermal camera, and there are a couple of things...
                  03-05-2025, 02:23 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
