Dell E172FPb/173FPb 17" monitor. screen + pwr led blinking
+ More Options
Posts
  • stalker7d7
    • Dec 2011
    The monitor is a Dell E172FPb/173FPb 17" (has both E172 and E173 on the back...).
    The problem is that it doesn't work, when plugged in and turned on it just blinks once every second or so, and the power LED blinks along with the screen. As if it's constantly restarting itself.
    The other problem, is that I've searched these forums, and when I find the same monitor, it appears to have a different board...
    I'm a newbie to working on monitors, so any help would be appreciated.
    I would have uploaded pictures but I guess I can't do that on my first post? "Your submission could not be processed because a security token was missing."
    Regardless, I'll get them uploaded some time soon, maybe use another website for them...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E172FPb/173FPb 17" monitor. screen + pwr led blinking
    Note the instructions and size limits below in my sig file. We want clear focused top down view of all your boards.
    Please upload the pictures here, not somewhere else.
    --- begin sig file ---
    --- end sig file ---
    • stalker7d7
      • Dec 2011
      Ah, I see. Max size 2 MB. What's listed in the attachments upload section is incorrect "jpg 3.81 MB 2000 2000"
      Hope these are good, had to reduce the quality to make them under 2 MB... lol
      • PlainBill
        • Feb 2009
        • 7034
        Excellent pictures, The classic cause of these symptoms are transistor pairs Q739-740 and Q759-760. Check these for shorts. If any of a pair are shorted replace both. Also resolder the transformer leads and the leads on caps C735 and C755. And check Q781? (between C763 and C794) and it's mate to the left of C751 for shorts.
        PlainBill
        • jetadm123
          • 2169
          There's a gent selling repair kits on ebay for your board for a good price. He's sold over 1400 of them, which should tell you something! Also, remember to resolder all the pins of the 4 small yellow inverter transformers.
          http://www.ebay.com/itm/REPAIR-KIT-E...item3355ff735c
          • Joshatdot
            • Jan 2015
            • 14
            I have this 173FPb .. originally it would turn on for 2 seconds, and then blank, power LED on.
            I got a similar replacement kit from ebay, replacing all 6 transistors : FU9024N x2, 2SC5707 x4
            But now after a few days after replacing them, I get the screen & LED blinking.
            edit: well, now the 173FPb is on & working. It only started to flash after I 'woke up' my PC. After being unplugged for a some mins, its working now.
            • HTR-Informatique
              by HTR-Informatique
              02-09-2025, 06:51 AM
            • ChristianBr01
              Dell 34 inch U3419W Monitor with thin stripes on partial screen
              by ChristianBr01
              I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
              This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
              This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
              Does someone have seen this before?...
              05-23-2025, 06:06 AM
            • Borse2008
              Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
              by Borse2008
              Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
              I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β€” it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
              • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
              • There’s
              07-15-2025, 04:55 AM
            • Swedishpower
              Dell G3 15 3500 black screen
              by Swedishpower
              Hello
              I have search everywhere for a solution for my problem, but cant find it anywhere.
              When I was away to trow some garbage i always look in the electronic bin.
              and this time i find a laptop.
              Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
              the lamp for charmig is white.
              Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
              but no Dell logo.
              I tryed with a hdmi cable to another screen, still black.
              I started to search solution and tryed...
              07-06-2025, 06:18 AM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
