Samsung SyncMaster 932B - screen intermittently goes black for 1/2 second
  • funkrhythm
    • Nov 2011
    Greetings,
    I've got a Samsung 932B LCD monitor that has an unfortunate affliction - every so often (the frequency seems to depend on the image) the screen goes black for half a second and then comes back. The blue power light on the power switch stays on continuously. I'm embarrassed to admit that it's been doing this ever since it was brand new - I originally bought it to use with an old laptop and for some reason I assumed that it was some kind of problem related to the video card. It's been in storage for a while and now that I'm using it again, I realize the issue wasn't related to the old laptop.
    When there's nothing on the display but my desktop background image (a picture of the cosmos, quite dark), the flickering on and off happens almost continuously (like every 5 seconds). Other times it will only happen rarely (every 5-10 minutes).
    I realize now I should have returned/exchanged the monitor as soon as I got it, but given that I'm stuck with it, is there any hope of fixing the problem? I am quite handy with a soldering iron and have a CS/EE background so I'm not afraid to take the monitor apart and replace components on PCBs if that's what it takes. I also have access to a scope, multimeter, etc. Most of the problems I've read about on this board seem to be related to bad capacitors, but I'm not sure how likely that is in this case given that it's had this problem since it was brand new (though I realized that doesn't rule it out).
    Any help or guidance is greatly appreciated! I'd hate to dispose of this monitor as it works fine except for the extremely annoying random blinking on and off.
    Thanks in advance
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung SyncMaster 932B - screen intermittently goes black for 1/2 second
    Originally posted by funkrhythm
    Greetings,
    Thanks in advance
    Well you're going to have to open it up at post some pictures; the really good guys around here would prefer that you do not post them inline.
    Is your 5 volts going to the logic board good and steady?
    Monitors will also use either 12v or 25volts for the inverter section and sometimes to the logic board, is that voltage good and steady?
    • Rtech
      • Jul 2010
      • 1095
      It is possible of course, that it is something as simple as an internal plug being loose,as no doubt the Monitor was subject to transit at various stages.It could also be a dry joint,which is a regular occurence.
        09-07-2024, 05:50 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
