Troubleshooting a Viewsonic vx1940w
  • mitch101
    • Oct 2011
    • 5
    When switched on, there is a buzzing noise, the desktop is visible for a couple of seconds then display goes blank. The blue power LED remains permanently on.
    Can anyone tell me if this fault is definitely a capacitor issue? The two 35v 220uf capacitors are slightly raised/domed.
    Cheers,
    Mitch
  • PlainBill
    • Feb 2009
    • 7034
    Re: Troubleshooting a Viewsonic vx1940w
    Cheers,
    Mitch
    The symptoms are known as 'Two seconds to black'. They have a number of possible causes, one of which is bad caps. Replace the caps with name brand low ESR caps (I prefer Panasonic FM, FR, or FC series) and proceed from there.
    It would be a Very Good Idea to replace all the electrolytic caps on the power supply / inverter with the possible exception of the large (100uF?, 450 volt one).
    PlainBill
    • mitch101
      • Oct 2011
      • 5
      ok thanks for reply.
      Buying a new power supply board costs about the same as buying a soldering kit and caps separately. I'll get a new board and report back for the benefit of anyone who has this problem in future with his monitor.
      Mitch
      • PlainBill
        • Feb 2009
        • 7034
        Mitch
        There is one practical problem with that approach - the new board will have the same low quality caps and will fail sooner rather than later.
        PlainBill
        • funkykryptonite
          • Jan 2012
          I just had the same problem as Mitch101. I replaced the two 220uf 35V caps with nichicon caps, and I am up and running right now on my viewsonic vx1940W. Thanks alot Plainbill, just saved my butt.
          • blues_spirit
            practical courses for troubleshooting pc motherboards
            by blues_spirit
            Hello from France,
            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
            Do you think this is feasible for me? I...
            12-18-2022, 12:56 PM
          • lostone
            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
            by lostone
            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
            05-19-2024, 11:40 AM
          • gcrezz
            GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
            by gcrezz
            The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
            07-25-2024, 09:49 AM
          • CrewmanRedShirt
            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
            by CrewmanRedShirt
            Hello all,
            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
            07-13-2024, 11:02 AM
          • Zippie
            Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
            by Zippie
            I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
            Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
            During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
            Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
            Opening the PSU the only things visible initially...
            03-07-2024, 07:58 PM
