Samsung T260
  • LAS
    • Sep 2011
    • 144
    Samsung T260
    Hi List Members,
    I am now the proud owner of a dead Samsung T260. It was made in May 2008, so I am hoping it doesn't have too many hours on it. It set me back $25.
    I took out the power supply circuit, and have attached some photos below. The caps look ok on appearance, but all the same I will change them just add to the reliability.
    At first glance, T301 looks like it became really hot; indeed, it does not have continuity across my ohm meter. Can anyone suggest a replacement?
    Also, I am thinking that something caused this to blow. There appears to be another hot spot just below the transformer, almost exactly where the 'Solder' arrow points.
    I read in another post on a T240 that I might suspect the transformer; I have attempted to take an ohm reading across the four different points, and I have annotated my photo. Can someone confirm that I did it correctly? If yes, does this confirm a dead transformer?
    Also, the hot spot in the direction of the 'Solder' arrow has a component below it, which I also suspect, for no other reason that it looks like it was hot once upon a time. Can anyone add their thoughts on this? I have added a closeup photo of that component as well.
    Thanks as always...
    LAS.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung T260
    Originally posted by LAS
    dead Samsung T260.
    Define dead.
    1) Does the power LED come on at all?
    2) Do you have any DC voltages at the connector on the power board? Measure and report the found DC voltage compared to what is written on the legend.
    --- begin sig file ---
    --- end sig file ---
    • LAS
      • Sep 2011
      • 144
      Re: Samsung T260
      Hi Retiredcaps,
      The power light comes on, but that is all that happens. No light at all from the screen, not even a quick flash of light.
      I will check the dc voltages later, hopefully tonight and report back.
      In my opening post, I stated that T301 looks like it was hot; actually, after looking at the board again, it looks like it was the resistor R301 that was hot. And it is open.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Samsung T260
        I would desolder R301 and verify it is completely open out of circuit.
        In addition, check picofuse F301 (the green one) just below R301. A good fuse should measure 1.0 ohms. You can measure the fuse "in circuit".
        It could be a simple fuse if you have no backlights.
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Samsung T260
          Also, what is the color band on R301? Your photo is nice and clear, but the colors are difficult for me to make out.
          • LAS
            • Sep 2011
            • 144
            Re: Samsung T260
            OK, here we go:
            Pin 1 PWM DIM reads 0
            #2 should be 15v - reads 15.4
            #3 s/b gnd - reads 0
            #4 s/b gnd - reads 0
            #5 s/b gnd - reads 0
            #6 s/b 5.2v - reads 5.4
            #7 s/b 5.2 - reads 5.4
            #8 A-DIM - reads 0
            #9 on/off - reads 0
            #10 s/b 3.3v - reads 0 (!)
            #11 LED - reads 0
            #12 KEY1 - reads 0
            #13 KEY2 - reads 0
            #14 GND - reads 0
            • LAS
              • Sep 2011
              • 144
              Re: Samsung T260
              Color band on R301 - I was about to consult the collective wisdom of the list because I couldn't make out the colors either.
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Samsung T260
                OK, here we go:
                What about the picofuse as per post #4?
                • LAS
                  • Sep 2011
                  • 144
                  Re: Samsung T260
                  Picofuse coming up next.
                  Meanwhile, R301 out of circuit now read 389k ohms.
                  • LAS
                    • Sep 2011
                    • 144
                    Re: Samsung T260
                    The green picofuse F301 just below R301 measures .2 ohms.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Re: Samsung T260
                      1) Fuse is good.
                      2) Let's get a picture of the main logic board.
                      3) When you press the on/off button, I believe pin 9 should go from 0 to over 3V DC.
                      4) I'm looking at some other pics on the Internet for colors on R301.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: Samsung T260
                        One of the reasons we (mainly PlainBill and I) insist on clear focused pictures is for this very reason.
                        I was able to find another identical power board (IP-54155A) on badcaps.net that had a slightly better picture.
                        https://www.badcaps.net/forum/attach...1&d=1275552641
                        On the above pic, I can make out orange, white, yellow. According to
                        http://en.wikipedia.org/wiki/Electro...r_and_inductor
                        that is 39x10(4th power) or 390,000. So your reading 389k is correct.
                        The resistor is good despite the burned look.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Re: Samsung T260
                          Okay, I didn't forget about this, but sometimes I don't work in the same order as everyone else.
                          According to
                          http://www.lcdparts.net/TransformerD...ProductID=3696
                          there are 4 secondary pins. The resistance should be 940 ohms between S1 and S2. Same for S3 and S4. If you are reading an open circuit, desolder the transformer and remeasure to verify.
                          If it is open, you have found the problem. There are plentiful replacement parts on ebay.com starting at $8 USD with free shipping.
                          • LAS
                            • Sep 2011
                            • 144
                            Re: Samsung T260
                            Sorry you didn't like the first set of pictures. To my untrained eye they looked ok. I also couldn't read the resistor bands as I looked directly at it.
                            Here are a couple of shots of the logic board. I won't be able to test the on/off bit until the morning, but I will get back to you at that time.
                            • LAS
                              • Sep 2011
                              • 144
                              Re: Samsung T260
                              OK, I remove transformer in the morning and let's see what that brings...
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Re: Samsung T260
                                Mosfets can get hot during operation and discolor the board. I have seen it many times and there is nothing to really worry about.
                                Datasheet is here
                                I would say if the inverter transfomer tests open out of circuit, you have probably found the culprit. If that is the problem, then you got a pretty sweet deal for $25 + $8 on a 26 inch monitor.
                                • LAS
                                  • Sep 2011
                                  • 144
                                  Re: Samsung T260
                                  Ha ha ha, it balances out that 2004 $30 one I bought a couple of weeks ago!
                                  I am still entertaining the idea of putting in new ccfl tubes and then donating it to our local school. They sure could use it.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Re: Samsung T260
                                    Don't get me wrong, they are good (better than 98.5% of the people who post here), but the other picture was better since I could actually make out the colors without having to "make the question fit the answer".
                                    Anyway, we now know the actual value and so will future people.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: Samsung T260
                                      If you put in new ccfls lamps, then be aware it is a very time consuming and fragile job. I did it once for a learning experience, but will probably not do it again. After I changed it out, I thought I had a nice 19 inch 2008 widescreen monitor. Then I turned it on and had a 1.5 inch vertical strip. ARRGGGHH. One of the tab bonds broke off and it is unrepairable.
                                      Step by step tutorial at
                                      http://www.ccflwarehouse.com/lasotu.html
                                      They are also sold "pre harnessed" to make the switch way easier, but obviously cost more.
                                      • LAS
                                        • Sep 2011
                                        • 144
                                        Re: Samsung T260
                                        OK, you just talked me out of it! I'm better off using my time to find other project monitors with more potential.
                                        While I'm at it, I'm thinking of changing R301 to something a bit beefier. Perhaps 2W. A good idea?
                                          09-07-2024, 05:50 AM
                                        • unimatrix93
                                          Replacement transformer for Samsung fridge
                                          by unimatrix93
                                          Dear forum
                                          My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                          No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                          The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                          My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                          07-14-2025, 02:16 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
