Samsung 245BW Problem
  • buggypartsplus
    • Jul 2011
    • 9
    Ok before you say that there are many other 245bw threads on this forum, I have read through most and can not find the anwser to my problem. I do get the blue light but black screen problem, but I have the BN44-00195A Powerboard. I have no 24v out or 5.4v out. PSON from main board is 3.2v when on and zero when off and I do have a standby voltage of 5.2v to main board. Help me please this one is driving me crazy!!
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung 245BW Problem
    https://www.badcaps.net/forum/showth...ighlight=245bw
    Have you read the above thread?Sounds very similar to me,with some things to test
    • buggypartsplus
      • Jul 2011
      • 9
      I saw that one and my voltage from pin 3 to pin 2 are 16.3v, but according to the data sheet the minimum is 16v.
      • alexanna
        • Mar 2010
        • 1346
        You are right at the minimum.
        Have you done any thing with the startup cap?
        • buggypartsplus
          • Jul 2011
          • 9
          I pulled it and tested for capacitance. I don't have an ESR. Should I just replace??
          • alexanna
            • Mar 2010
            • 1346
            If it was me I probably would,But i usually have to ask for help on the SMPS.
            Maybe One of the other Guys would have an answer
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
              09-06-2024, 11:40 PM
