lg flatron 1970hr-bf need help finding caps
  • squish1188
    • Jul 2011
    my monitor has an external power supply, i took it apart today because it was flickering and found that it had two capacitors blown.
    the problem is i can't find replacements from any company that match the series
    and I'm not sure about what series would be good to swap to
    I'll put down everything i found on these capacitors:
    CapXon
    1000uf 16v
    GL series (theres the biggest problem)
    105c
    c610 ?
    vent ?
    20mm x 10mm
    5mm lead space
    any help would be greatly appreciated
  • PlainBill
    • Feb 2009
    • 7034
    Re: lg flatron 1970hr-bf need help finding caps
    Without a location, I can't suggest a supplier, but there are a number of caps that fit your requirements.
    Panasonic EEU-FM1C102, EEU-FC1C102S
    UCC EKZE160ELL102MJ20S, EKY-160ELL102MJ20S, ELXZ160ELL102MJ20S
    Nichicon UHE1C102MPD, UPW1C102MPD
    Vishay MAL214655102E3
    With the exception of the Vishay, all are rated for 105°C and cost between $.55 and $.75 each. The Vishay is rated for 125°C and costs about $1.50.
    PlainBill
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • fl0w
      GeForce 6800GT recap, need help identifying caps and finding replacements
      by fl0w
      I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
      But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
      I need to replace:
      • 2x 2.5V 1500µF => I plan to use this
      • 2x 16V 330µF=> I plan to use this
      • 1x 6.3V 680µF=> I plan to use this
      Am I correct with the cap choices?
      Thanks for...
      10-02-2024, 11:28 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
