acer monitor no display
  • lhock98
    • Aug 2010
    • 63
    hi guys,
    i need helpl to fix my acer AL1916w monitor, when power the monitor is have green light but when i switched on my CPU it started to give me a flashing orange light. anyone know what wrong is it?? kindly take the picture for reference, your help is deeply appreciated.
    [/IMG]
    [/IMG]
  • retiredcaps
    • Apr 2010
    • 9271
    Re: acer monitor no display
    1) If you are going to be a regular here, you will have to stop posting images inline and offsite, please. They slow down loading of pages. Please use the manage attachments to upload your photos so they are hosted here.
    2) You have 3 obviously bloated caps.
    Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    Most members here will recommend that you replace ALL the electrolytic capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, and United Chemicon are suggested. A list of recommended caps can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    3) PCBONEZ talks about how to choose the right series at
    https://www.badcaps.net/forum/showpo...47&postcount=3
    4) If you want to use Panasonic FR/FM/FC, see PlainBill's ordering instructions at
    https://www.badcaps.net/forum/showpo...33&postcount=2
    --- begin sig file ---
    --- end sig file ---
    • lhock98
      • Aug 2010
      • 63
      [QUOTE=lhock98;170776]hi guys,
      • lhock98
        • Aug 2010
        • 63
        sorry i seldom post thread here, yea i saw the 2nd pic 3 caps need to replace.
        regarding the 1st pic left bottom some burn mark is there is it some parts worn off??
        • retiredcaps
          • Apr 2010
          • 9271
          I can't tell from that angle or lighting on my monitor. All I see is that some of the white glue is darkened.
          Maybe post another angle with different lighting. A pic of the backside would help too.
          • lhock98
            • Aug 2010
            • 63
            hope this should help..thank for your reply.
            • retiredcaps
              • Apr 2010
              • 9271
              The resolution is too low to make out anything.
              If you can, try for 2000x2000 resolution of the sections in red. If your camera has macro mode, enable to get sharp focus. Also, try to use indirect sunlight to help get clear and well lit pictures.
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                Hi hate to state the obvious but there should be a fuse there
                • UniT3d
                  • May 2011
                  • 43
                  Does that look like it was hit by a lightning surge? F103 should be Wickman fuse 3.15A 250V and VAR100 should be a TVR10681KSY varistor 420VAC 70J 2.5KA At any rate, I believe everything in the primary section needs checking first (especially the power FET).
                  • lhock98
                    • Aug 2010
                    • 63
                    here the zoom up view as requested by expert retiredcaps. f100, f101, f200 with the letter s,w,w. which is the bottom side of the board and i have checked f200 need to replace also the 3 capacitors. i can't find the f103 dont know where is it.
                    • lhock98
                      • Aug 2010
                      • 63
                      just found the f103 they using a small wire direct connected to point a to point b. not using any fuse...
                      • lhock98
                        • Aug 2010
                        • 63
                        i have replaced the f200 and 3 botted capacitor, i still can't getr any display from monitor when i power on my CPU. the monitor only have green light on the on-off switch.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          The latest pictures are excellent. This monitor has a reputation for problems with the inverter. I note that an input capacitor is missing, and of course F103 should be replaced. The fact that you are now getting a power LED indicates that at least part of the power supply is working. I am concerned there is additional damage. F103 blew for a reason.
                          There are a couple of additional steps.
                          First, does the power LED respond when you press the power button?
                          Next, the connector which links the power supply / inverter to the signal card appears to have 16 pins. What are the voltages on these pins? Use a mounting screw as the ground point, or if you are working from the bottom, exposed metal around a hole for a mounting screw. Of course, caution while working on the board while power is applied is suggested.
                          Last, high resolution pictures of the top and bottom of the inverter / power supply are needed.
                          PlainBill
                          • lhock98
                            • Aug 2010
                            • 63
                            very thanks for your reply. First of all the F103 its do not have a fuse there at the bottom side there is a small thin wire connected from point to point. i don't know why there is a burn mark near to input main power (220v). the bottom side F103 thin wire did not break off so should i leave it? if not what type of fuse should i buy for F103??
                            PlainBill
                            • lhock98
                              • Aug 2010
                              • 63
                              the 16pins power supply to inverter i have checked all pins at 0 volt. what's wrong?
                              PlainBill
                              • sabre504
                                • May 2010
                                • 449
                                • United Kingdom
                                Sorry to butt in .
                                the thin wire where the fuse should was most likely put there because it kept blowing fuses.
                                1 Are you getting power at the main cap (not read if you have )
                                2 i would check the bridge rectifier and thermistor (usual culprits for blowing fuses )
                                3 2 types of fuses used on this board (see pics) both are 3.15ta 250v
                                • lhock98
                                  • Aug 2010
                                  • 63
                                  the main cap is reading at 720....
                                  Originally posted by sabre504
                                  Sorry to butt in .
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    720? 720V AC? 720V DC?
                                    Either way, 720 units is really high.
                                    You should be measuring DC volts across the main cap. Do you have your black probe on the negative leg of the cap? Red on positive?
                                    • lhock98
                                      • Aug 2010
                                      • 63
                                      o.k here is it 330dc. main cap is o.k , right?
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        That is correct if your AC line voltage is 240 volts.
                                        PlainBill
