I would suggest you assemble the boards back onto the panel
With the mains lead plugged in check the voltages on the lead that connects the psu to the main board ( record them) .
Then power up the monitor checking the voltages on start up (record them)Wait for the back lights to go out and check the voltages again this way you can see if the voltages are going over or under what is needed to supply the logic board to far out of spec and you will get white screen .
Also test the small smd fuse on the lcd panel .
You may have to sort your backlight problem before you tackle another problem that could well be being caused by the first problem (if that makes sense)
