ACER AL1916 blinking green light of death
  • dmcfarland
    I have an Acer AL1916 monitor. It goes blank and the light above the power button blinks green. This happens when the computer is off for an extended period of time and it takes some time for it to right itself. I am reading other posts about this problem and wonder if its a waste of time for me to even fix it.
    I have an IT background and took electronics in high though I am rusty. Any ideas on what I need to get this thing working and how long should I let it discharge? Thanks
  • retiredcaps
    • Apr 2010
    • 9271
    Re: ACER AL1916 blinking green light of death
    1) Most LCDs have a bleeder resistor that will discharge the largest filter capacitor in about 1 to 2 minutes when the power is removed and unplugged.
    2) You will have to take apart the lcd and post clear focused pictures of the boards using the manage attachments function. Please do not post pictures inline.
    3) The symptoms sound like potentially bad capacitors. To replace the capacitors, you will need a soldering iron, solder, desolder pump or solder wick. Caps will cost around $10 if you are in the USA. Time to take apart, solder, fix, etc will be about 20 to 60 minutes.
    edit: Feeling of fixing it yourself: priceless
    --- begin sig file ---
    --- end sig file ---
    • dmcfarland
      I'll buy a new monitor anyway, and try to fix the one that is malfunctioning. If I succeed Ill use the old one as a spare. I try to have as many spares as I can. I have a spare motherboard, and cpu lol. Thanks for the reply.
      • jetadm123
        • 2169
        Eventhough there's a bleeder resistor to drain the large cap, as a point of safety, I normally put my meter across the large cap to verify it's drained. I've had a few occasions where the cap was still fully charged.
        • smason
          • 1652
          Good plan. I picked up a Mac G5 power supply that had been unplugged for 10 minutes. Bzzzzt! Launched it across the room. I'm more careful now.
