Gateway FPD2485W LCD Repair - Success
  • ryankam
    • 36
    Monitor had no power, no lights and made a arcing sound when the
    power button was pressed. Upon opening and inspecting the unit I came
    across many capacitors on the main board and the power supply with leaking
    capacitors. I replaced (2) 10V/1000uF,(3) 35V/470uF, (3) 10V/470uF & (1)
    25V/1000uF capacitors. The 25V/1000uF & 10V/470uF capacitors with higher
    voltage capacitors (35V). After soldering the capacitors I successfully was able
    to power up the monitor and test the VGA input. Sorry I did not document the locations of the capacitors. But they were all very obvious!
  • dragon3x
    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
    by dragon3x
    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
    power on.
    Here are some examples :
    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
    switching supply area).
    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
    than 6.3 V.)
    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
    I replaced capacitors with aluminum-polymer.
    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
    03-21-2025, 02:46 PM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • Ady2017
    Are there any datasheets available for Elna RJG capacitors?
    by Ady2017
    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
    05-25-2025, 02:19 PM
  • ctroxtell
    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
    by ctroxtell
    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
    01-03-2025, 08:57 PM
  • Fahd Qureshi
    Missing Capacitors- MSI RTX 2080
    by Fahd Qureshi
    Hi All,
    I recently purchased as MSI RTX 2080 SEAHAWK X, which isn't working. I noticed there are 2 capacitors missing from the back- see images. I am wondering, could this explain why the card won't work? I appreciate any help!
    11-12-2024, 12:20 PM
