Samsung Syncmaster 2220wm
+ More Options
Posts
  • RobertoIsRad
    • Nov 2009
    • 42
    Hi I got a monitor for free from craigslist because it didn't work.
    When you connect the monitor and turn it on everything works perfectly...for 2-3 seconds then it shuts off and you have to turn it back on and again only stays on for a few seconds...
    So I did a little investigating and the internet lead me to believe that the caps on the power supply were bad. So I replaced everything capacitor wise on the power supply and video board with 1:1 matches of a better brand (nichicon? I went off the good caps FAQ).
    Imagine my disappointment when I hooked it back up and found that the problem was the same after all my work.
    So I'm just wondering if anyone here has any suggestions on what else I could check or replace.
    Thanks in advance!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 2220wm
    "2 second to black" can be
    a) bad caps
    b) bad inverter transformer
    c) bad ccfl or wiring
    d) bad inverter sense circuitry
    Since you already replaced the caps, focus on b) and c). It is documented starting with posts 13 and 14 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    PS. Clear focused pictures using the manage attachments help. This is also discussed in post 14 under the misc suggestion.
    --- begin sig file ---
    --- end sig file ---
    • RobertoIsRad
      • Nov 2009
      • 42
      ok, thank you. I'll test some of the things outlined in that post and reply what happens
      • RobertoIsRad
        • Nov 2009
        • 42
        Pictures Incoming
        Barcode is on bottom. Pin one is bottom most
        1) Bad Capacitors
        All replaced and the problem stayed the same. So I have to assume it's something else
        2) Shorted Transistors/MOSFETs
        D804
        1-2= 1 .
        1-3= 00.3
        2-3= 1 .
        D805
        1-2= 1 .
        1-3= 00.3
        2-3= 138.1
        D807
        1-2= 1 .
        1-3= 00.3
        2-3= 121.5
        3) Open fuse
        f801= 00.3
        f802= 00.3
        4) Bad transformer (truthfully I don't know what I'm doing here and the video was removed...)
        T801
        Left Side?
        1-2= .000
        1-3= 1 .
        1-4= 1 .
        2-3= 1 .
        2-4= 1 .
        3-4= .000
        Right Side? Secondary stuff?
        1-2= .000
        1-3= .000
        1-4= .000
        1-5= .000
        2-3= .000
        2-4= .000
        2-5= .000
        3-4= .000
        3-5= .000
        4-5= .000
        5) Bad CCFL
        I would have to take apart my good working monitor to get an extra ccfl to test with so I'd like to avoid this if at all possible.
        Might be a stupid question but can i rig an old case lighting kit for these tests? I think I've got one of them in the closet
        6) Bad/cold/poor solder joints
        looks OK to me. We'll see after I get some pictures loaded
        7) other bad components
        **Voltage regulators**
        My "U" chips look different from normal VRs. I have u501 and u502 and they are 8 legged chips
        **Resistors**
        R525 - Should be 1.5Mohms, +/-5% and is 1.481Mohms at 2M setting
        R801 - Should be 1Mohms, +/-5% and is .922Mohms at 2M setting
        R802 - Should be 1Mohms, +/-5% and is .918Mohms at 2M setting
        R803 - Should be 18Kohms, +/-5% and is 17.42Kohms at 20K setting
        R805 - Should be 0.18ohms, +/-5% and is 00.4ohms at 200 setting
        R806 - Should be 10ohms, +/-5% and is 09.6ohms at 200 setting
        R816 - Should be 100ohms, +/-5% and is 92.3ohms at 200 setting
        R517 - Should be 33ohms, +/-5% and is 30.9ohms at 200 setting
        **Diodes**
        For whatever reason I did these ones from the top of the board. Power plug on bottom of board, black starts on left or top
        D806
        L-R= 1.965
        R-L= .605
        D803
        T-B= .496
        B-T= 1.
        D802
        T-B= 1.
        B-T= .520
        ZD802
        L-R= 1.
        R-L= .521
        8) Inverter IC sense circuitry/feedback
        Is this on the power board, logic board, or the long board still attached/taped to my lcd screen?
        I'm going to post pictures tomorrow when the sun comes out and maybe you guys could point it out.
        Thank you for your help!
        • RobertoIsRad
          • Nov 2009
          • 42
          Pictures as promised
          • jsog
            • Feb 2011
            • 220
            On the bottom, the middle lead of those three left of the Q801 label looks very close to touching the pin above it. The cap leg just to the left of them looks bad.
            • RobertoIsRad
              • Nov 2009
              • 42
              I trimmed the lead you thought was touching, and it didn't change anything. I don't know which leg you're talking about though.
              • RobertoIsRad
                • Nov 2009
                • 42
                Ugh, I thought I would take it apart again to have a better look at the board and now the piece of crap won't even power on anymore.... This might be the last nail in this coffin. Any ideas?
                • jsog
                  • Feb 2011
                  • 220
                  C822, the right-hand connection in the photo doesn't look like the solder wetted to the leg. But it's probably just a little ceramic and isn't significant. Solder on the right pad on the replacement cap right above it, C820, looks questionable, and that one might be significant.
                  • RobertoIsRad
                    • Nov 2009
                    • 42
                    I think that it might just have been the light when I took the picturebecause they look good right now.
                    Also I think I mis-spoke, I changed out all the barrel shaped caps. I never did anything with the disc shaped ones because I don't know how to find the specs for a replacement
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Any ideas?
                      Okay, let's slow it down first.
                      1) Does the power LED light come on at all?
                      2) Are all the internal cables inserted/seated properly?
                      3) I have attached your picture (excellent btw) where the secondary transformer pins are. With power off and lcd unplugged, put your multimeter on 2000 ohms (if manual) and measure the resistance between the 2 yellow dots. Report measurement. Do the same for the red dots.
                      • RobertoIsRad
                        • Nov 2009
                        • 42
                        1) No LED at all, Before it used to turn on as soon as it was plugged in. Then when I pressed the power button I would get the 2 seconds to black. Now it's off if I press the power button or no. I may have popped f802 originally it was reading 00.3 now it's 1 . I'll try to jump it if you think that might be the cause to this most recent problem at least
                        2) Yes, i've unhooked/hooked everything up a few times and looked at all the cables and they look undamaged.
                        3)
                        Yellow Dots
                        .462
                        Red Dots
                        .468
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          1) No LED at all.I may have popped f802 originally it was reading 00.3 now it's 1 .
                          3)
                          Yellow Dots
                          .462
                          Red Dots
                          .468
                          If the fuse is reading "1" on the left hand side, it is definitely bad. I'm not a fan of jumpering to bypass a fuse. A fuse exists for a reason.
                          Let's test the following with power off and lcd unplugged for shorts first before replacing the fuse.
                          1) Check D801 (bridge rectifier) for shorts. Number the pins 1, 2, 3, and 4. Test 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4 for shorts. This test can be done "in circuit". Any ohms reading under 30 ohms suggests a short. Remove D801 if any reading is under 30 ohms and retest "out of circuit".
                          2) Check Q804 for shorts. Number the pins 1, 2, and 3. Test 1-2, 1-3, and 2-3 for shorts.
                          The 2 inverter transformer readings suggest they are good.
                          If you are going to order a new fuse, order 2 or 3 in case it blows again.
                          • RobertoIsRad
                            • Nov 2009
                            • 42
                            D801 and Q804
                            All combinations yield a "1 ." I assume this is not good? I'm set at 200 on my MM.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              D801 and Q804
                              If that is the symbol for 'over range', that indicates they are NOT shorted. In other words, good.
                              PlainBill
                              • RobertoIsRad
                                • Nov 2009
                                • 42
                                Great, thank you!
                                My two monitors you helped me fix last year are still ticking away nicely PlainBill, Thanks again for that!
                                • RobertoIsRad
                                  • Nov 2009
                                  • 42
                                  Before I waste my time and potentially risk ruining my nice working 22" samsung monitor...what are the odds that the connections and things would be the same (working monitor is a little newer)?
                                  There's a board on ebay and if I can use my working monitors board to test I think that might be the best route
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Before you buy the board, what caused the fuse to blow? Was it your soldering? Was it your multimeter probes slipping and causing a short?
                                    Since your power mosfet and bridge rectifier are good, it may make sense to replace the fuse now. After you replace the fuse, you can test the power board separate from everything else. If power board has voltage on the secondary outputs (like 5V DC), then the power board is good.
                                    • RobertoIsRad
                                      • Nov 2009
                                      • 42
                                      ok, I'll see if I can find a fuse tomorrow and put it in.
                                      I believe it blew because I was too lazy to put all the screws back in when I tested it, which must have allowed the board to hang down a little bit and come into contact with the metal cover on the lcd
                                      edit:
                                      I found this fuse http://www.radioshack.com/product/in...ductId=2103767 will this work? Above the fuse on the board it says T4A/125V which I assumed meant 4 amps 125 volt. It might look a little ghetto with a holder for it mounted on, but at least it'll be easy to change!
                                      • RobertoIsRad
                                        • Nov 2009
                                        • 42
                                        The fuse was the cause of my power failure, I replaced it and it turns on with 2 secs to black like before.
                                        The two outputs measured 5.1 and 5.09 so then my power board is good? Leaving me with bad ccfls or a bad logic board?
                                          09-07-2024, 05:50 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
