Re: Needs caps for my 22" lcd
Links were very helpful. Unfortunately, the removal of the my ccfl's were much different that the link above so I had a hard time getting to them. Well, I suppose "much" is relative. In anycase I had trouble accessing them.
I ended up pulling lcd apart to get to the ccfl's . . . I think I pulled the lcd apart way more than I had to.
I realized that upon pulling them out Perhaps I will document my steps for the next poor sap like me with an lcd like this one.
Question about the bulbs:
1) Since I had such a hard time pulling out the bulb, I only pulled out the one that was easiest to access at the time (the bottom one). I feared I would not be able to put them back in properly for some reason so I only took out one for the moment. How likely is it that both bulbs are defective ? I am under the impression that if one of the 4 (or 1 of 2 pairs) bulbs are not operating properly, it will shut them all off after a second or so (which is what's happening). Should I pull the top 2 bulbs out for inspection too ?
2) In between the 2 electrodes (after the stainless steel caps) the white glass bulb part, there is blk powder of sort that's inside the the glass envelope. Is that normal ? It's worse on one side than the other (see pic 1)
3) (see pic 2)
Also, not sure if the blk corrosion present between the electrode and stainless steel caps will preclude or prohibit the bulb from operating properly (though I'm sure it does not help). Is this an indicator the bulb is no good ?
4) To ensure it's just not the connection that is the problem, or the cause of the problem, should I cut away the black heat shrink around the solder/electrode to inspect the connection? I mean, I would probably want to re-solder the connection to ensure good connection anyways, right? That, or inevitably replace the bulb, which will require I clip the leads from the electrodes anyway.
Just looking for proper action to take since I've got this far already. I'd hate to make a mistake this far in... I'm so close.
Def will do soon.
3) (see pic 2)
Def will do soon.
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
