Samsung 205T flickers, whines, then shuts off
  • TheMatrix
    • Feb 2011
    • 3
    Hello-
    My faithful Samsung 205T failed a few months ago, and was awaiting me to have the courage to chuck it. It'd turn on, flash the display on for a second, the power light would flicker, then shut off. From past experience, if it was a backlight issue, the LCD would still work (with a flashlight) and power wouldn't be affected. But with this, even the power status light was flickering.
    Then while dealing with a friend's faulty motherboard, I learned of bad electrolytic caps, and thought to take the back off my display before throwing it out. Sure enough, I see two Samxon GF caps that are bulged. Given my symptoms, I think it's a pretty good bet that's the culprit.
    There are only two bulged caps (820 uF 25v - Samxon), but 4 other caps on the board from CapXon that look fine - should I replace the rest anyway? I might as well, they're so cheap and the board is so easy to work on. Is there a good brand to go with? For these caps, DigiKey lists: Panasonic ECG, United Chemi-Con, Cornell Dubilier Electronics (CDE), and Nichicon.
    There is a huge 180uF @ 450v cap that's a Samxon GF series, but appears to NOT be bulged. Should I replace this one anyway? I ask because it's about $8 at DigiKey, and I don't want to waste money if not necessary. And if I do replace it, what's a good brand? DigiKey lists: Panasonic ECG, United Chemi-Con, Cornell Dubilier Electronics (CDE), Nichicon, EPCOS, and Kemet.
    The power supply board is single-sided, and very, very easy to work on. I guess I should mention I have a background in electronics and have been regularly soldering for about 20 years, so I'm capable of the extra work.
    Thanks!
    -TM
  • smason
    • 1652
    Re: Samsung 205T flickers, whines, then shuts off
    I'd replace all but the Huge one, it's likely ok.
    And I'd use Panasonic FM or FC caps from Digikey.
    • jetadm123
      • 2169
      Unless the 180uf is leaking or bulged, then you don't need to replace it. It operates under a lower stress than the smaller ones do. By all means replace all 6 of the smaller caps, since the Capxons are a known "problem" cap. Use a low-esr cap like the Panasonic FC,FM or FR series.
      • TheMatrix
        • Feb 2011
        • 3
        Wow, thanks for the fast replies! I will leave the big one alone, and replace all the others with the ones suggested.
        • TheMatrix
          • Feb 2011
          • 3
          I'm placing the order now, but I see the 47uF cap (Panasonic FC) has a 1000 hour rating, where the Panasonic EB has 7000 hours. Which should I go for?
          • jetadm123
            • 2169
            EB series is not low-esr. Stick with the FC series.
              09-07-2024, 05:50 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
              Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
              This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 06:20 PM
