Samsung 305T - Is this the Altera BGA chip issue?
  • bugman74
    • Feb 2011
    Hi Guys,
    I have a 3 year old samsung 305T that just started to exhibit a strange issue. Its hard to exlpain, but its a blue distortion. It flickers and moves all around the screen. It is especially bad when there is a dark background. I attached a couple pics.
    Is this the Altera BGA chip issue? I can have it reballed for about $100, but want to be sure before I spend the bucks.
    Thanks,
  • jetadm123
    • 2169
    Re: Samsung 305T - Is this the Altera BGA chip issue?
    If you haven't done so, take it apart and post good focused photos of the entire power supply top and bottom. Also, post a photo of the logic board. Do not post photos inline, but use the "manage attachments" button.
    You also might want to read the following:
    https://www.badcaps.net/forum/showth...highlight=305t
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • Stephen
      A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
      by Stephen
      As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
      5.16V .47amp
      5.16V .47amp
      5.16V .47amp
      5.16V .04amp (this guy is the issue) (U3200)
      So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
      11-27-2023, 03:57 PM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
