Westinghouse 37" LVM37w3 troubleshooting.
Re: Westinghouse 37" LVM37w3 troubleshooting.
So I was feeling lazy on the weekend, didn't order.
I'm ordering it today, but I came to question the rubycon yxg 25v 100uF, should I replace them? Teapo, Taicon and Capxon are a given, but I heard great things about rubycon so should I replace them?
edit: Also Does teapo boost their specifications? I seem to having hard time finding matching ripple current. Teapo SC series both 50v, one is 4.7uF and other is 10uF.
4.7uF = 115 ripple, I assume milliamps, but the close thing to it is 95mA Panasonic FC.
10uF = 140 ripple, Close thing is Panasonic FC @ 125.
If I go up in voltage, I don't get any closer to hitting teapo specs, so I assume that they are padding the specs to make them look good?Last edited by Mad_Professor; 03-29-2011, 08:05 AM.Comment
As far as the Rubycon cap, Rubycon has a very good reputation. It's your call. Personally, I'd replace it because I hate worrying that I missed something that will come back to bite me.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
http://search.digikey.com/scripts/Dk...name=P14413-ND
FC costs 34 cents
http://search.digikey.com/scripts/Dk...name=P10269-ND--- begin sig file ---
--- end sig file ---Comment
I'll buy FR for the rubycon, just in case and hold off on replacing them. FC for the small caps.
should I replace D11 and D12 diodes?
D11 is on the first leg of the transistor circuit after ZD1 and D12 is on the second leg of the transistor circuit. Since I'm already replacing zeners, would it be good idea to replace the D11 and D12 too? Or wait and see?
Just want to make sure, because I don't want to pay for second shipment if I don't need too.
d12 is BYV2, but glue is blocking the rest, it's hard to remove, below the 2 is a zero.Comment
D12 tested ok, D11 on the hand is getting interference from being in circuit. I could remove it but it's glass diode that is glued. I could destroy it during the extraction process.
In one of previous picture band color is Black followed by Pink. If I look at it, I can't tell if it's brown or pink. So how can I identify this?Comment
Awww, crap!!! I just spent 20 minutes searching various schematics for a possible ID of that diode. Most of them didn't show a resistor-diode pair like that. Those that did either didn't ID it, didn't have a parts list, or said 'not used'. Then I FINALLY did find one. It's a 1N4148
Digikey 1N4148WXTPMSCT-ND should work for you.
.120 both ways, not sure if it suppose to be like that since it is in parallel with the resistor above.
I'm gonna finish placing the order, I'll add the diode so I have it on hand.Comment
Parts came today, I guess I'll start putting it back together. Do zeners have a polarity requirement or can they just be install no matter what orientation?Comment
I think I'm gonna start soldering this thing back together today, how can I tell which side of the zener is ground? is there like a notch or band or something to tell me?
edit: never mine there is ridge on one side it was hard to see through the packaging. SO I guess ground goes on left where large red band on zener in the previous pic goes even though the trace on right goes to ground. Am I correct?Last edited by Mad_Professor; 04-06-2011, 01:42 PM.Comment
correction again... I tested the old zener and found that big red band is indeed ground and the new one has a very thin ridged band and testing it with the diode setting on my dmm I was able to figure it out, that was ground.
BRB going to solder...Comment
Before powering up, make sure you check the datasheet for correct polarity. Datasheets help reduce the guess-work.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
I didn't find anything about polarity in the data sheet.
I was wondering if a 40 watt appliance light bulb would work when I'm testing it?
Also sometime during the winter I had the set cover up pretty good with the plastic housing on, and I think one of my cats or both of my cats got under there, I now I have tons of flea dirt everywhere, on inverter board, metal and everything. Is this going to cause a problem? How can I clean it?Last edited by Mad_Professor; 04-06-2011, 03:51 PM.Comment
You're definitely not mistaken. There is no info on polarity in there so I'm kinda baffled myself. Someone else will weigh in soon and help out with this.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
A Zener diode is a diode that has been manufactured and selected to have precise conduction characteristics in the reverse direction. Where a normal diode might be able to withstand 100 or even thousands of volts in the reverse direction, a Zener is usually designed to withstand only a few volts.
A conventional diode has a band at the cathode end - it conducts when the anode is about) .7 volts positive with respect to the cathode. A zener diode uses the same convention. If you connect the banded end to ground and apply +20 volts through a 1K (or large) resistor, it will conduct at the rated zener voltage - 15 volts in this case if I recall correctly.
OR you can use a DMM with a diode test function. With a conventional diode the diode test will show a reading when the black probe is on the banded end. With a zener diode it should show a reading when the red probe is on the banded end.
Using a 40 watt bulb for the initial tests is a very good idea.
As far as cleaning up the cats mess, I'd suggest using a paint brush to loosen the dirt and compressed air to blow it toward the cats.
uh oh... black probe was on the banded end and I got reading when the red probe was put on the other end. But on the glass one the black probe was on the thick red band end and red probe was on the green end. Anyways I set it up the same way which ever the black probe was on the new zeners it was the only way to tell.Comment
Well I tested it, nothing crazy happened, the bulb came on then went off.
Now what?Comment
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by blues_spiritHello from France,
mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
Do you think this is feasible for me? I... -
by EchooFujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?11-25-2024, 01:54 AM
by smartyCan anyone identify logo shown below?
The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
Neither ChatGPT nor Copilot know the correct answer.
TIA1 Photo - Loading...
