Re: need help with a gateway lp2407/fpd2484
It is an fr30-10 the data sheet can be found at www.datasheetarchive.com
the markings on the diode are
FR30-10
469Leave a comment:
I should have known I seem to be fixated on the power switch because I have no clue on how to test it .
I made a stupid mistake when unsoldering the board after hearing 3 load pops I reliazed that I forgot unplug the power and dischard the filter cap I may be getting to old for this . I cant see any burnt areas are cracked parts so maybe the is no uncoverable damage .
PlainBillLeave a comment:
I made a stupid mistake when unsoldering the board after hearing 3 load pops I reliazed that I forgot unplug the power and dischard the filter cap I may be getting to old for this . I cant see any burnt areas are cracked parts so maybe the is no uncoverable damage .Leave a comment:
That explains the voltage. The isolation transformer is a nice touch, wish I could find mine (how can someone lose an isolation transformer?)
I'd like a picture of the daughter board if possible. I realize that's pretty cramped. What is the part number of the IC?
Its 185 but I am using an isolation transformer that 133vac outLeave a comment:
it is a homemade meter made from instructions from http://ludens.cl .Leave a comment:
What type of ESR meter do you have?Last edited by retiredcaps; 02-15-2011, 01:40 PM.Leave a comment:
If you are in the USA, your mains are 120V AC. Voltage across the main filter capacitor is 120V AC x 1.414 = roughly 165V DC.
0.5 ohms ESR depending on the uF, voltage, diameter, and height of the cap can by too high.
For example, a Panasonic FR 1000uF 25V cap has an ESR of 0.018 ohms according to
http://search.digikey.com/scripts/Dk...name=P14425-NDLeave a comment:
Let me explain my insistence on pictures. First of all, Gateway does not build these monitors; rather they are designed and built by one or more companies in China. As a result an FPD2484 can have one of several different power supplies, LCD panels, and even signal cards. Telling someone to measure the voltage across C10 (start up capacitor in one design) would be meaningless if in his version C10 was a line noise suppression cap.
Even in the case of a single power supply, I would have to first locate a picture of the power supply (schematics are very hard to come by for Gateway products), then identify the critical points to measure.
I think one of the main problems here is lack of photos. You may think they are unimportant, but since we're not sitting next to you or looking over your shoulder, it's hard to follow what's going on. Members need good focused photos to suggest what components to test. And they need to see photos of YOUR boards, since there are probably different revisions/configurations out there. And finally, I agree with pedro and PlainBill that the 135V across the main cap is a problem.Leave a comment:
sorry if I offended you .Leave a comment:
there are no indicator lights the only voltage that I can check is the raw input voltage which is 135vdc . Trust me pictures will not help I have examined every connection with an eye loop and removed every cap and measured its esr all are less than .5 ohms . I suspect that there is no on signal from the front panel but I dont know howm to test it . It is a switchless device.
But since you know more than I do, fix it yourself.
By the way, you should be asking yourself why the input voltage is 135VDC.
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
Channel: Schematic Requests ONLY!
04-25-2025, 07:01 AM -
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Channel: BIOS Requests ONLY!
Gateway ID49C04u ID49C11u Laptop Schematic...
Channel: Schematics and Boardviews
11-01-2024, 06:46 AM -
Gateway NV53 Series Laptop Schematic
Wistron SJV50-TR 09228-1 48.4FM01.011 Rev 1M...-
11-01-2024, 02:54 AM -
- Loading...
