Samsung 2493HM issue
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Samsung 2493HM issue
    Originally posted by werthles
    I tried to get my camera to focus on that chip and to no avail. Ill note what numbers i see around it. Maybe IC304 is its part number.
    1) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    2) IC304 is the PCB board designation.
    --- begin sig file ---
    --- end sig file ---
    • werthles
      • Feb 2011
      • 24
      #42
      Ok, i will play around with my camera tomorrow when the sun is up.
      • Skurg
        • May 2011
        #43
        Was Werthles able to repairhis monitor? I have a 2493HM with the same blown cap but with no led when powered up. Haven't gone much further than this. Any thoughts?
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Same as above. Post pictures following the guidelines in my sig file below.
            09-07-2024, 05:50 AM
          • vincentedel
            Samsung SyncMaster 740n Phase Control Issue
            by vincentedel
            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
            04-22-2025, 12:33 AM
          • Manucsl
            QE65Q800TATXXC Samsung TV Issue
            by Manucsl
            Hello.
            My TV is a QE65Q800TATXXC Samsung TV.
            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
            Any ideas to check would be very appreciated 😊
            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
            02-19-2025, 07:47 AM
          • FourRunner
            Display issue Samsung TV UA65JS9000W
            by FourRunner
            I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
            10-03-2024, 07:05 PM
          • ScHAmPi
            Samsung UE48JU7000 screen issue after backlight replacement
            by ScHAmPi
            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
            07-15-2024, 05:41 AM
