Samsung Syncmaster 570 STFN image issue
  • G Nicholls
    • 19
    I am having a screen image issue with this LCD monitor. This is a real "old dog" with a external 12V supply, so many of you will not have seen many of these. The problem is best described as a sync or timing issue.
    There are horizontal lines interlaced evenly with the image lines.
    These images seem to behave a bit like a slowly rolling image on a analog TV screen when the vertical sync is not locking.
    There is a "herringbone" artifact moving thru the entire screen image.
    The video image is set to 800X 600 60Hz. No LCD select for this video card.
    Changing resolution or refresh rate does not cure the problem (yes I know. LCDs dont use the CRT refresh rates).
    So I think I have a sync problem with the video board. I is not AC noise from the outboard power supply as I did substitute it with a known clean 12VDC source and the problem persists. Also substituted cables and computers to eliminate that issue. It is presently running (with the problem) on a well maintained test bench computer.
    I suspect a problem with the large scale integrated circuit that generates the screen image. But due to the numerous outboard support components, I would like to eliminate them as the culprit before "moth-balling" this unit. A open ground, bad timing Xtal, or stray signal corrupting the syc signal are all within reason. I am just not sure where to look without a schematic or some direction from somone who has had a similar problem (and fixed it).
    Reading the posts at this forum has helped me greatly. Most repairs are within my scope now. But there is the occasional trouble that I MUST CONQUER. Well, from a tech-nic-ian competancy point of view, anyway.
    So any tips would be appriciated.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 570 STFN image issue
    Let's start with clear focused pictures using the manage attachments feature. Please do not post pictures inline as they slow down the loading of pages.
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • vincentedel
      Samsung SyncMaster 740n Phase Control Issue
      by vincentedel
      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
      04-22-2025, 12:33 AM
      09-07-2024, 05:50 AM
    • rattlesnake
      Samsung SyncMaster 955DF dim image fix
      by rattlesnake
      This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
      To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
      08-12-2023, 07:03 PM
    • shlomim412
      samsung ua55es6800 - no image
      by shlomim412
      hi
      having problem with samsung ua55es6800
      tv had backlight on, sound working - responds to the remote control but no image.
      check tcon board - had 12v in but no other voltages present.
      when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
      when leaving only left side connected - again no voltages and no image.
      put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
      kept trying to block less pins on the left ribbon cable...
      05-15-2024, 05:00 AM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
