Samsung 23" LCD P2350 Inverter Repair
    replied
    Re: Samsung 23" LCD P2350 Inverter Repair
    Originally posted by lule.nikolic
    I wonder could I have the same problem with the mosfets and how to check them?
    Get the data sheet of the MOSFETs and check for short circuit between Source and Drain, Gate and Drain, and Source and Gate for each MOSFET. In particular, any short circuit between Gate and any other pin makes the MOSFET highly suspicious. In such case, remove MOSFET and test out of the board.
  • CroTech
    replied
    Also the whole board was recaped with Samxon capacitors
  • CroTech
    replied
    Nice repair, just bought the same monitor. At first it had 2 seconds to black, then I measured the secondaries on the inverter (1400271 C 09TM13-C) and they were like 1.1kOhm and 96kOhms so I changedt it with TMS 92903CT which had secondaries 1.6kOHms.
    Turned it on, and it was working for a few seconds and since then I cant turn it on at all.
    I suspected the schotky diode so I tested it and all pins were shorted, desoldered it and tested again, turned out good and not faulty.
    And if I have the same problem could anyone write it on the picture in the first post which mosfets are IRF540N and which IRF9540N? Thanks in advance.
  • whistlergonewild
    replied
    If you replace the fet/pwm on the heatsink please let me know the outcome. I posted the cap sizes and some high-resolution photos on this thread that you may be able to find the part numbers from without having to open the monitor again. I have opened my monitor so many times now that I have it down to a fine art.
  • fishstix
    replied
    Well I've replaced the two little FETs that drive the transformer. Managed to find the replacement IC parts (the two little 8pin SOIC). (This is what was at the start of the thread but I managed to find the actual parts)..
    And! Just the same. Resoldering the caps previously didn't help so think I'll either for for replacing the caps and/or replacing the fet/pwm with the heatsink...
    Now I need to open up the monitor again to get that part number..
  • whistlergonewild
    replied
    hey fishstix, If you end up finding a replacement piece please update this thread and tell me how it goes.
  • fishstix
    replied
    It seems to be a real common problem. Quite a pain as its a nice monitor when it works.
    I've just resoldered the caps (getting that back lid off is a pain) but still experiencing same thing.
    I'll buy some replacement caps and give it a go. Might see if I can track down a replacement to the combo FET/PWM controller that you're cooling. Since that's having an effect its either working too hard due to something else broken, or is actually the broken piece.
  • whistlergonewild
    replied
    Hey fishstix. The only time I had positive results is when I had a 12V fan blowing on the heat sink. So I don't know if replacing the component the heat sink attaches to would solve anything but putting a fan to it did. Also Im not sure the part number or how to order that piece, but I did google the issue I'm having and I read somewhere that this is the culprit of all mayhem, then again I also understand how it could be the caps, but since I have replaced the caps twice with no success Im thinking it's the other component.
    I think I'm going to hook the fan back to the 12v and use the monitor only as a backup.
    Hey....anyone interested in buying a monitor that works some of the time? $60 and it's yours.
  • fishstix
    replied
    Any further luck with this? My monitor is exactly the same and starting to exhibit the same problems with turning off. Quick google and its common fault.
    Seems to be heat/time related as it happens after being on for a few hours. I'm happy to strip it down and replace the caps but before doing that would be nice to hear some positive results.
  • bomcla
    replied
    controls the output transformer of lamps. probably is not working properly!
  • retiredcaps
    replied
    Post a picture of the top of the Rubycon cap and the bottom of the cap. The top should have a "K" style bent, if not, they are fake. If the bottom has a "bulleyes" bung, it is fake.
  • whistlergonewild
    replied
    Well I had it on for 10 minutes and then it switched off...the control buttons on the bottom stay illuminated, and then after a few minutes they turn off then back on with the display. So still the same results....on for ten minutes then off for minute, no difference even with the new caps.
    Any ideas what to try next.
  • whistlergonewild
    replied
    Ok. So I finally got my caps in the mail. The first picture are the ones I bought on ebay from hong kong. The others I bought at a Japanese electronic store on Main St. in downtown Vancouver.
    I have replaced the caps and so far so good, but I've only had my monitor on now for 8 minutes....see what happens....keeping my fingers crossed.
  • PlainBill
    replied
    Originally posted by retiredcaps
    Hmm, I just assumed his badcaps username told us he lived. Home to Canada's first Olympic gold medal on Canadian soil.
    And yes, the Canadian presence of *any* merchandise online is pretty terrible.
    While I am sure Whistler is a wonderful place to live, the fact is 'Whistler' has a number of possible meanings. And some of those are pretty wild.
    PlainBill
  • retiredcaps
    replied
    Originally posted by whistlergonewild
    In a small village called Whistler.
  • Dgtech
    replied
    Sorry Mad Professor. I live 2 hours north of Vancouver, BC, Canada....the great white north. In a small village called Whistler. I primarily buy all my stuff online. A large amount from ebay.
    I didn't mean to insult anybody here by buying from ebay, but I didn't know any better and I was having some difficulty finding caps online in Canada....so the simplest was to go to ebay. I know better now though.
    Anyways my friend gave me his monitor so now the Samsung 23" is on the backburner as a project.
    Updating profile with location help people from the same area help you find parts that you need.
  • smason
    replied
    How's it goin' eh?
    Digikey.ca is pretty good but flat rate $8.00 Overnight shipping to Canada is the only option, so only worth it for larger orders.
    I don't think anyone is offended, but now you knoe Ebay not so good for caps. Good for transistors though, go figure....
  • whistlergonewild
    replied
  • Mad_Professor
    replied
    Why did you buy them off ebay? Do you not live in the US? Digikey, mouser and badcaps has caps for sell and they are about a dollar or less per cap.
    if you order from digikey they offer the first class mail option which is the cheapest and the fastest shipping option they have.
    Stop beating around the bush and just buy good quality ones.
    replied
    In that case defiitely post some pictures when you get them.
    I looked through his store, and from the pictures there, it doesn't look too good at all.
    Anyone want Rudoycon KYA (Rubycon fakes ) or green Nichicon caps with a H3058 datecode for that matter?
    I think you got fakes, unfortunately, but we will see.
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
    This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 06:20 PM
