Re: Samsung 23" LCD P2350 Inverter Repair
Yup, earlier monitor had the same symptoms as now... It turned on and off after 2 seconds, so I checked the inverter transformer and it was faulty, replaced the transformer and again it worked for 2 seconds and then nothing, I could not even turn it on, not even the LEDs, so I found out that the MOSFETs were shorted, so replaced them too, and now I have 2 seconds to black again.
Do u mean to check the new MOSFETs?
And, I´ve read that you can check the CCFLs without having a spare CCFL bulb, u can just unplug one connector and than try?
Since you had indicated earlier that some of the MOSFETs had blown, did you rechek them?
Notes on the lamp per your link, I never try that kind of form factor, I tried other form factor, the twisted type as shown in my pictures work. I will have to get one like the one in your link to try out.Last edited by budm; 01-28-2013, 12:57 PM.Leave a comment:
Will this one do the thing?
http://www.chipoteka.hr/artikl/95450...#tab-specs-tab
Do I need one or two?Leave a comment:
Cold Cathode Fluorescent Lamp = cathod bulb, just my term...
I could buy one ccfl tomorrow, but how many wats and any special specifications?Leave a comment:
I dont know exactly what you mean by cathod bulbs. I dont know if you have seen it but Budm has this - its a lot cheaper just for a test than buying ccfls.
https://www.badcaps.net/forum/showth...ght=test+lamps.Leave a comment:
nope, I dont have cathod bulbs.... I could buy one then test it.
Should I check anything elseLeave a comment:
That is bad news, have you any spare ccfl bulbs or anything you can test the panel from this one in. ( Could be a faulty bulb or wiring)Leave a comment:
transformer came in today... Has both secondaries at 996Ohm
Nothing changed, the monitor keeeps shuting itself down after 2 secondsLeave a comment:
the original inverter is this http://www.ebay.com/itm/Inverter-Tra...-/250862284136
I will buy it and replace it and then I´ll get back to u, many thanks.
Just out of interest did you test the old one - which pins?Leave a comment:
I will buy it and replace it and then I´ll get back to u, many thanks.Leave a comment:
The power board in post #11 uses a QGAH02113 inverter transformer available here:
http://www.ebay.com/itm/QGAH02113-In...item2578c0e1b3
Don't know if it will work because you may have a different revision of the same board. Perhaps budm, selldoor or others may have a comment about this.Leave a comment:
I would suggest getting the correct transformer, you haver to match the DC resistance which you can check with the Ohm meter, but you also need to match the inductance of the transformer, and also the input/output voltages, the current output, so it will put out correct high voltage to fire up the lamps.Leave a comment:
As I said in your other thread and someone else also mentioned we 'think' you have to replace like with like ie1200ohms with 1200 ohms OR perhaps change some resistors or something so that the protection doesnt kick in and switch the lamps off.
Unfortunately I dont know enough to be certain.
Perhaps ask the question in general electronics. eg "can I replace a faulty inverter transformer with 1200 ohm secondaries with a transformer with 1600ohm secondaries.
or visa versa and if not why not?Leave a comment:
for am4512c I would have to wait about month or two... Both secondaries ar exactly at 1,68kOhm and the one I replaced had one at 1,21kOhm and other at 98kOhm. What could be the problem now?Leave a comment:
AM4512C is available on ebay the important thing on inverter transformers is that the
secondary windings should measure the same (within 3%) if there are two secondaries on one transformer. If the transformer has only one secondary then it should measure the same as the other transformers if there is more than one lamp.
If there is a number of transformers ,as is often the case on a tv inverter board, each transformers pair of secondaries should be the same and every transformer should be the same.Leave a comment:
mosfets had gates shorted, no replacements so I did the same fix like in post one... thought i have it fixed when it turned on but it turned off in a few seconds... now the red led stays on but the screen keeps shuting down after 2 seconds... did I put in the wrong transformer, does it need to have both secondaries at 1,21 kOhm cause I thought the most important thing about transformer is primary/secondary ratioLeave a comment:
The problem is mosfets are so small i cant read what is written on them... I will try taking a picture of it then zooming in. I read that u need a bias current so u can check a mosfet?Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
