Viewsonic VX2235MW
  • truxforu
    Viewsonic VX2235MW
    Does anyone know, can the DAC-19M009 AF power board be replaced with the DAC-19M010 AF ??? Thanks
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Viewsonic VX2235MW
    The main thing is the output voltages and the current protecion circuit for the lamps. If the pinout for the connectors is the same voltages then try it and see. If it goes 2 seconds to black, most likely there is a difference in the current protection circuit. I've swapped some before and they worked fine but thats after I confirmed the ouput voltages to the digital board.
    • truxforu
      I'll check the outputs, thanks
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
      • lostone
        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
        by lostone
        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
        05-19-2024, 11:40 AM
      • gjgib
        Help reading schematic voltages input/output
        by gjgib
        Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
        I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
        I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
        I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
        05-06-2024, 08:11 PM
      • RossMoodley1967
        HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
        by RossMoodley1967
        Hello
        Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
        Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
        03-01-2024, 06:07 AM
      • karlp028
        MSI Z390-A PRO missing VCORE voltages
        by karlp028
        I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
        06-23-2025, 01:25 AM
