Re: Hanns-G HG281D 28" TFT - Multiple Problems
I always buy carefully when it comes to broken monitors. I have bought and fixed and sold dozens of monitors and I have only been shafted twice. One of those I didn't even pay for. You are right jet, and I would not recommend for anyone to so this without the proper experience and tools to handle the problems that may come up. I do this because I enjoy it, although it does bring some income. Not much, just some to fill in. This hobby pays me. If only my other, more expensive hobby did too...
If you can get it cheap enough, then it's worth the gamble. Just understand that a lot of folks think that it's only a cap issue and $10 worth of caps will solve the problem. If you have read the threads here on a regular basis, then you see problems such as bad/broken ccfl's, transformers, logic cards, etc. You can imagine the cost/time to replace a ccfl on a 28" monitor. Not to mention that some parts are simply not available. However, if it winds up that you can't fix it, then you can always part it out and sell the parts on eBay to recoup some of your money. And if you do fix it, then it's money in your pocket.Leave a comment:
I bought another hg281d and again replaced the caps on the logic board. It fixed it. The monitor had different symptoms though. This one wouldn't stay synced up. It would show an image through the hdmi port for a sec then go black with the backlight on and the osd say there is no signal. Then vga port acted different. Displayed image fine for a duplicate display, but wouldn't display at all for only disp or extended display. This one was made in 2009, the other was made in 2007. The symptoms were different, boards were different and caps different, but the problem was the caps on the logic board in both cases. May not have been all of them, but they are cheap enough to replace them all. I am not implying this is the only problem that may come up so check other possibilities before ordering caps. BTW, I have 2 now side by side. Should I go for another?Leave a comment:
I got image back by doing exactly as you peeps advised..
Now Its still acting up but now it shows bright spots over dark colors..
Ill try to post a pic when it really shows..
TY for the help.Leave a comment:
In my experience a white screen appears when I forget to connect the signal cable. It connects the logic board to the lcd board. If it happened after opening the device it is more likely. Check those connections again. Report back.Leave a comment:
Pictures should be uploaded using the manage attachments function and please do not post inline.
The maximum pic size resolution is 2000x2000 and I believe 2MB. Resize your pic accordingly.
You most likely have a cable that is not seated properly inside the lcd. Reseat all your cables.
Am i doing something right/wrong?Leave a comment:
I replaced all of the caps on the logic board. So... re-solder all of the lytic caps on the logic board and see what happens. Be sure to remove as much of the old solder and replace it with fresh solder.
I might be wrong so don't be too disappointed when it doesn't work.Leave a comment:
Oh sweet. thanks for the tidbit there.. I just hope anyone has seen the pics so they can tell me where to soder!Leave a comment:
I read through this thread to fix a broken HG281D I bought. I have fixed many others before but have invested much more time into this one. I finally consented to order the caps for the logic board as stevekasian did. Thanks btw. It fixed it. Mine would power on for about 30 seconds then shut off with only the power led 'on'. It also had shimmering in the white of the image. All of that is gone now. Before that, I checked the entire PWB for a problem. I did find 3 bad caps on the power board. C111, C603, C707. Not sure if those affected it in the ways I noticed.
I have a feeling that the problem with the logic board is not bad caps, but bad solder joints. I didn't try it, but if someone wants to try to resolder all of the caps on the logic board to see if it works, I would like the feedback. Of course if that doesn't work, replacing them would verify if the problem lies in this board.
I hope my input can help someone else.Leave a comment:
Hi Again. I uploaded the pics of the monitor boards to flickr and made them public.
http://www.flickr.com/photos/61176240@N08/?saved=1
I hope its easy to fix. ty for taking the time to look at them and giving me a opinion.Leave a comment:
Ty for the Info. I shall reseat the cables and take pics in smaller sizes.
Anyhow I just put the monitor back together and now the screen is White???
Did I put it back together wrong?Leave a comment:
Hi, I found this forum via google because I have problems with this exact monitor..
i have the one Made in Aug 2007 and I been having problems with my monitor making a popping sound when I turn it on Alt tab playing WoW and other apps.
I also starts up when I turn it on and takes a while for the image to show up, Although the image shows up well it starts to flicker from the bottom part of the monitor and then vertical lines appear to shimmer and dissapear.. ive taken the monitor appart and checked to see for any damage and I looked around the board and capacitors to see if anything is burned or damaged.. I took some pics of the boards and I wanted to show the forum to see if i can get any imput on how to fix it..
Any help is greatly appreciated..
Odd I cant add any pics because of this "vBulletin Message
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
Thanks Stevekasian!
Ordered the same caps you listed from Digikey +1 extra
Monitor works perfectly now,
Great forum!Leave a comment:
Hi fixologist1,
Sorry it's taken so long to respond; I haven't checked this thread in a while!
I would guess that it's probably the logic board caps, as that's what mine was doing even when it wasn't shutting off. I replaced ALL of them. Well, almost. I counted wrong and ordered 1 short, so I left the best looking one on the board. :-/ Count carefully!
SKLeave a comment:
Hey guys... I'm back!
I just got my Logic board caps in yesterday and replaced them, albeit with one hell of a struggle; Those things did NOT want to come off! They used some really crappy looking solder on this board. It was all dark gray and oxidized looking, and kept a very coagulated consistency when liquified. Very difficult to remove with a solder sucker. The best way I found to deal with it was to heat both legs of a cap up at once and just slather a bog ol' ball of 60/40 rosin core solder over both pins, then suck it all up.
This is a tricky board to work with though, because it's double sided - etched on both sides. With each cap, one pin was connected to a trace on the back of the board and the other to a trace on the front side of the board. This means that when using a solder sucker on the pin connected to the back, the solder comes right up. But when you attempt the same with other pin, only the surface solder comes up... because the rest is all stuck down inside the lining of the hole in the PCB. The trace from the front side goes through the hole to the back side, then terminates in a very small surface "ring" to which the component is to be soldered. So the main contact point is INSIDE the hole.
I had to destroy quite a few of the old caps by pulling them off their pins and then just pulling the pins out individually while melting the solder from the back side. This left many instances where the hole was left clogged with solder. In those cases, I stuck the iron tip (very pointy) into the hole on the front side of the board and used the solder sucker on the opposide side to suck it through. (This worked well, but a couple of PCB traces came up in the process... SO BE CAREFUL!) After a while, I realized another method worked even better: Slip one pin of the new cap all the way through the hole that's open and just lodge the other pin into the clogged hole. Then, pushing down on the cap from the front, heat the clogged hole from the back side and it will slide right through.
Also, something to be careful with is the installation of the 4 largest caps along the IC... the 2 470uf and the 2 "taller" 100uf caps next to them (taller then the OTHER 100uf caps found elsewhere on the board). The replacement caps will likely be a bit shorter and fatter, so you'll want to stage 2 or 3 of them at a time BEFORE YOU SOLDER THEM to make sure they're positioned properly for a fit. I had to kind of tweak a couple off to the side, etc., to provide a little more clearance.
Conclusion:
The logic board caps were definitely my problem. The power board caps were causing the thing to run extremely hot, but replacing all of them had absolutely no effect on the video problems I was having. This was absolutely necessary, however, as, if nothing else, they were causing my electricity bill to go thru the ceiling with this thing, and causing some kind of scary-high temperatures inside the case to boot. It runs so cool now there's hardly any heat coming off of it at all after hours of use.
The only issue I have now is that there seems to be a bit of discoloration along the sides and two parallel areas of discoloration along the center, side by side. What it actually APPEARS to be is possibly some darkness on the flourescents - like they're getting old and burned a little bit. But that's just a guess. It's definitely that "yellowish" color that is often times related to bad fl. lighting. But there are a couple of issues that preclude me from being able to get to the bottom of it without more work:
#1. I accidentally counted the caps wrong and was one 10uf 16v cap short... so I looked at all of them with a magnifying lense and chose to keep the one cap that appeared to have no corosion visible around the top crown of it.
#2. Upon installing one of the 470uf 16v caps (the largest ones), I may have pulled on it a little too hard trying to adjust the legs after installation (they were too wide, so I had to bend them to get them to go in with proper clearance). I *may* have damaged the cap in the process, but I'm not sure at all.
So either of these 2 points could be the problem... OR, it could just be that the entire logic circuit has changed enough with the new caps to bring to light some another issue - namely, old fl bulbs that need replacing.
I'm not worrying about it too much though, because the only time it's visible is when I have a giant, maximized empty IE window with a bright white background emblazened across the entirety of the screen. And I try to avoid that annoying sight as much as possible anyway.
It is also worth mentioning that I always used to have barely visible vertical lines of shimmering pixels that would rapidly "sparkle". They were only visible when inspecting the screen very closely, and seemed to be background dependent. They appeared to me to be related to the other screen issues that would appear whenever the monitor was not wanting to cooperate and would keep shutting down, coming back on, etc.
Also, when it would shut down, sometimes it would come back on with a distorted screen. It would be like there were 2 screens superimposed upon one another, with one slightly shifted off the right side of the screen and wrapped around back over on the left side. It would have to shut down again to get corrected.
All of these issues are now Solved. Other than the very minor backlight issue, the screen is absolutely PERFECT and I couldn't be happier!
Thanks again to all you wonderful people who helped on this thread. You gave be the confidence to tackle something I never dreamed I could handle... which saved me about $200!
All the best,
Steve
Hi, I have a similar problem as you have described, ( shimmering lines of pixels) but the picture is also shimmering. I am not sure if this is caused by the problem pixels, or if both problems can be resolved by replacing the PSU and Logic Board caps? My monitor does not shut down itself or have any power problems that i can see.
Hope you have some suggestions,
Thanks.Leave a comment:
It is likely a blown fuse, shorted mosfet, or shorted transistor.
2) Please post clear focused pictures using the manage attachment button. Please do not post inline.
3) And NO, your board is NOT identical to the OP. Manufacturers make changes all the time and even the slightest change is significant so we want to see pictures of your board.Leave a comment:
Hello stevekasian,
My unit is powering up and down OK and I can see images on the screen but no back lighting. Getting 24 volts to inverter board but no light.
Some have said it is a logic board problem and I know you replaced caps on it. Did you replace all those little devils????Leave a comment:
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by npielawskiI will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...Yesterday, 01:53 AM -
by CrystaleyesHi all.
I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
by fuxxyUN55D6000 I've posted about before.
Initially had bad backlights, of which both entire strips were replaced.
Then TV started not staying off. Every poweroff command was recognized, TV would power off then power right back on, even with nothing attached.
Now, no output at all. No red Power LED, No response to remote. No clicking or coil whine.
From other threads, tested various outputs on the PSU. Noticed that when the mainboard was unplugged, the backlights would turn on.
Backlight Connector CNL802:
Logic board unplugged:
pin... - Loading...
